TWR-K65F180 SDRAM Clock
926件の閲覧回数
Mike_d
I was wondering if there was a reason the SIM_CLKDIV1/OUTDIV3 is set for 24MHz and not 60MHz.
-Mike
812件の閲覧回数
danielchen
Hi Mike:
The SDRAM uses CLKOUT as SDRAM clock, when MCU power up, the MCG is not initialized, the core/system and bus clock use default clock. For K65, the default bus clock is about 24M, but you can configure it as 60Mhz
