Request for Improved C Plus Plus Support
razed11
Contributor V
I've started using the networking module RTCS. There are a number of include files that do not seem to declare extern "C" linkage when appropriate.
Others have asked about this and the answer has been to use extern "C" {} in our code. The responsibility for this should be in the library maintainer however. It clutters our code and you only find out when you go to link. By version 4.1.1 I would think this has been dealt with.
Will Freescale sign up for this in the next release?
Kenny
macl
Senior Contributor I
Hi Kenny,
Thanks for your input.  I can check to see if it can be done for a future release.
Mac L
razed11
Contributor V
Thanks for checking in to this.
