Real time tasking
Real time tasking
1,669 次查看
OldPeculier
Hi all,
Does anyone know of a good document with examples for implementing real time tasks in general?  I have an application that requires good time accuracy and low jitter.
Cheers!
标记 (3)
1,490 次查看
c0170
Senior Contributor III
Hello OldPeculier,
I am not aware of any document you asked for.. If you are more specific about application requirement, we can help you..
MartinK
1,490 次查看
OldPeculier
Thanks MartinK,
The application is CAN, the requirement is for sending sync events precisely.
I think the MQX timer component will do the job and I was looking for a clearer example.
I am also worried that the resolution is only 1ms.
Cheers
MartinH
