PWM code for TWR K60N512
2,064 次查看
nidhinnn
Can anybody help me with a code to create pwm in twrk60. I have tried to generate code, but its not working well. Its very urgent.Please help me.
Nidhin
1,898 次查看
nidhinnn
Hi Daniel,
Thank you for your reply. I have tried to execute the bare code you have provided. But i am getting only distorted pwm out put signal (The signal is some what similar to distorted sinusoidal out put). Please let me know if it is due to any execution problem. I will check it by myself and let you know the result.
Thanks and regards
Nidhin
1,898 次查看
danielchen
Hi Nidhin
Please check attached project about how to use Flextimer to generate PWM signals, it is based on bare board
If you are using MQX, please check the demo code,
C:\Freescale\Freescale_MQX_4_1\demo\pe_demo
Wish it helps
1,896 次查看
danielchen
Sorry, forgot attachments, now attached.
