MQX with Codewarrior on Kinetis Micro
已解决
跳至解决方案
2,951 次查看
Briwal
Codewarrior 10.1 BETA added kinetis microcontroller support.
Is MQX supported with this version of Codewarrior?
From what I can see, Kinetis MQX (version 3.6.2) is supported only in IAR.  Has anyone seen otherwise?
标记 (3)
1 解答
1,693 次查看
DavidS
Hi Briwal,
You are correct.  CW10.1 BETA has baremetal support for Kinetis.  The FSLMQX3.6.2 only supports IAR tools today.  Next release of FSLMQX in April-ish time frame should have CW10.1 support.
David
在原帖中查看解决方案
1 回复
1,694 次查看
DavidS
Hi Briwal,
David
