MQX task manager
MQX task manager
2,902件の閲覧回数
Teckna
Contributor V
Is there a way to implement a task manager function in MQX 3.8?
Useful informations to show could be task execution time, memory use and so on...
Many thanks
Teckna
7 返答(返信)
2,654件の閲覧回数
KJFPE
Its built into the IDE ie in IAR use the menu MQX -> Stack Usage etc
2,653件の閲覧回数
Teckna
Contributor V
My will is to report the application behaviour in field (runtime) not in developing process, sending the data on a serial channel (I use printf)
Many thanks
Teckna
2,653件の閲覧回数
c0170
Senior Contributor III
Hi Teckna,
have you read Getting Started with Runtime TAD Tool for Freescale MQX™ RTOS? I believe that's what you are looking for based on the description.
MartinK
2,653件の閲覧回数
Teckna
Contributor V
Hi MartinK,
I'm not able to find the document you talked about, nor in my PC nor in the Freescale internet site. Where can I find it?
Many Thanks
Teckna
2,653件の閲覧回数
c0170
Here's the path :
\doc\tools\cw\MQX_RuntimeTAD_getting_started.pdf"
MartinK
2,653件の閲覧回数
Teckna
Contributor V
Sorry, it comes with MQX 3.8.1, I was serching in the backed up 3.8 folder. Now I start to read it.
Many thanks
Teckna
2,653件の閲覧回数
Teckna
Contributor V
I've not read the document you point me to, I'll read and then I'll let you know.
Many thanks
Teckna
