MQX task manager
MQX task manager
2,946 次查看
Teckna
Is there a way to implement a task manager function in MQX 3.8?
Useful informations to show could be task execution time, memory use and so on...
Many thanks
Teckna
7 回复数
2,698 次查看
KJFPE
Its built into the IDE ie in IAR use the menu MQX -> Stack Usage etc
2,697 次查看
Teckna
My will is to report the application behaviour in field (runtime) not in developing process, sending the data on a serial channel (I use printf)
Many thanks
Teckna
2,697 次查看
c0170
Senior Contributor III
Hi Teckna,
have you read Getting Started with Runtime TAD Tool for Freescale MQX™ RTOS? I believe that's what you are looking for based on the description.
MartinK
2,697 次查看
Teckna
Hi MartinK,
I'm not able to find the document you talked about, nor in my PC nor in the Freescale internet site. Where can I find it?
Many Thanks
Teckna
2,697 次查看
c0170
Here's the path :
\doc\tools\cw\MQX_RuntimeTAD_getting_started.pdf"
MartinK
2,697 次查看
Teckna
Sorry, it comes with MQX 3.8.1, I was serching in the backed up 3.8 folder. Now I start to read it.
Many thanks
Teckna
2,697 次查看
Teckna
I've not read the document you point me to, I'll read and then I'll let you know.
Many thanks
Teckna
