MQX library step in debugging - every instruction
1,382件の閲覧回数
preetmehta
So I am using Atollic and MQX library with Kinetis K61 as my core.
I am using mingw to build the mqx library and compile the builded library with my project.
but I am not able to debug into the source of mqx. (I know this is totally vague but still...)
so what are the options if I wish to debug the mqx source also using atollic
タグ(2)
1,196件の閲覧回数
danielchen
Hi Preet:
I think maybe you have stripped the debug information from the MQX library.
Anyway, please check the user guide for getting started with Atollic.
http://www.nxp.com/assets/documents/data/en/user-guides/KSDKGSATLUG.pdf
