MQX in power down mode
1,919 次查看
MarcosPereira
Is it possible to run MQX in power down mode, waking only from RTC e UART interrupts?
标记 (1)
2 回复数
1,301 次查看
PetrM
Senior Contributor I
It works for RTC, check RTC example.
You have to set actual interrupt level above all except for RTC and UART interrupt levels before going to sleep mode.
PetrM
1,301 次查看
ARQuattr
I looked through the RTC example but it's not clear how/where it goes into low power mode. Any tips on doing this through MQX, especially for MCF51JM? I'm looking to wake from a pin interrupt.
