MQX V5 Libraries Command line build
3,521件の閲覧回数
Vidya_1203
Can you specify the instructions to build mqx v5 libraries from command line? I have tried the instructions specified in the attached document,  but there are lot of differences between mqx v5 and mqx 4.2.
Also is there any documentation to build mqx project using mcuxpresso ide?
2 返答(返信)
3,471件の閲覧回数
Vidya_1203
For anyone else having the same question, I am attaching the guide to integrate/build MQX RTOS v 5.2 with MCUXpresso IDE.
3,510件の閲覧回数
danielchen
Hi @Vidya_1203
I would suggest you contact the owner of MQX, Embedded Access for this question.
https://embedded-access.com/
