MQX Copilation issue
2,320 次查看
kirankunnath
When i tried to compile MQX source ( iam using MQX 4.0) using MinGW, its giving an error - "error: stdint.h: No such file or directory".
where is this stdint.h file located? please help me to resolve this issue. Error log is attached.
2,077 次查看
c0170
Senior Contributor III
Hello kiran kunnath,
what makefile are you using? what's your settings? Because I see Code Red paths on the screen. The stdint header file is not part of MQX. That header file is part of standard library. I assume your path settings are not correct.
0xc0170
2,077 次查看
kirankunnath
Hello Martin,
When i tried to compile an example code hello (which is in MQX 4.0 examples) using MinGW, compilation error is coming. I have attached the error logs. I would like to know where can i find the gcc version of the files __arm_start.c and __arm_end.c supporting freescale K60 for Redsuite compiler which are missing.
2,077 次查看
kirankunnath
Could you please provide startup files __arm_start.c and __arm_end.c files supporting freescale K60 for Redsuite compiler.
