MQX 4.2 Websocket problem on Ethernet over USB
patrickcaujan
I ve got a disconnection problem on a websocket.
When I use a pure Ethernet connection, everthing is fine. When I use a connection "Ethernet over USB", websocket receive a "disconnect" signal without reason ....
the "USB link" has no problem with a classic TCP/IP connection .
Have you got an idea ?
THanks.
danielchen
Hi Patrick:
Could you share me how to  reproduce this issue with Tower-board?
