MQX 3.7 httpser example can't work at MQX4.0
hoknrspwos
Hi all,
     Recently, I started to learn how to use HTTPD. So I tried to execute httpdsrv example in MQX 3.7 + IAR 6.1 and the other one in MQX4.0 + IAR 6.6.
     Of course, the both examples can work fluently.
     Now the problem is why httpd_server_run(server) always is wrong when transporting the httpser example of MQX 3.7 to MQX 4.0 + IAR 6.6 compile environment.
     It can't show the right Web Page, even though I have changed all MQX libraries and other relative settings.
     It's a so confusing problem.
   Thanks for everyone's response.
    Platform: NK2635 (TWRK60N512)
susansu
Hi alan,
     Have you configured the ip address of your PC in the same subnet with the board's?
