K22F512, MQX and USB...
1,823件の閲覧回数
yb
After reading that K22F512m120 was supported by MQX, I was looking for USB lib.
But USB seems is available only for KDS, not for CW / MQX (other lib are available for CW + MQX).
Is there a reason ? Is there a solution to have USB lib under CW ?
2 返答(返信)
1,653件の閲覧回数
danielchen
KDS is a replacement of Codewarrior for the new ARM Kinetis devices, I suggest you move to KDS for future Kinetis development.
Please take a look to the following post that shows the difference between Codewarrior and KDS
Comparing CodeWarrior with Kinetis Design Studio | MCU on Eclipse
1,653件の閲覧回数
yb
Daniel,
I tried KDS last week and I didn't found a usable IDE...
I spend a lot of time (several years now) on CW Eclipse + MQX, found a lot of bugs, learned operations and making my experience with, so, I don't understand why FREESCALE decide to change IDE, without real reasons.
For exemple, today, I have a new project where K22FN512 is just the perfect reference (hardware and internal peripherals). On this board, I need SD card, USB OTG (plus some glue).
With KDS, I found some exapmples for SD in SPI mode (for TWRK22 even if the FRDM board have a footprint for SD connector...), but without MQX.
It's very diffcult to understand how KDS shall work...
With adding Processor Expert, no more results.
With KDS, I found that all is very hard to understand and to test.
MQX was clear, "simple", usable and useful. Not KDS case...
I will wasting the end of this week to find a solution (how to simply use KDS or porting target under CW+MQX) and it will be finished for me (20years of MOTOROLA / FREESCALE). It's abnormal to waste 2 full weeks to reach any results nor any solution...
I'm really surprised that so few other developers complain about KDS !
Yvan
