How to check the TCP/IP upload speed?
ソリューションへジャンプ
2,038件の閲覧回数
danielchai
Senior Contributor I
Hi All,
I am using K60, and MQX4.0.2.
Is there any way to check the TCP/IP upload speed?
Thanks.
1,914件の閲覧回数
Luis_Garabo
Hi Daniel,
Some time ago I wanted to know that same thing and I used Wireshark tool for that. I used a similar information as this one:
speed of sending and receiving packets - Wireshark Q&A
I hope this helps you.
Garabo
2 返答(返信)
1,915件の閲覧回数
Luis_Garabo
Hi Daniel,
Garabo
1,914件の閲覧回数
danielchai
Hi Garabo,
Thank you, that's want I need.
