How to access function source in RTCESL
pavlinstoyanoff
Greetings! I am new here. I`ve downloaded the RTCESL, inculuded the files into a new project in Keil uVision as the datasheet says. There are many functions in this pack whick code is in .lib files. These functions are defined are extern in the .h files. How can I access the source code in this case? I want to see the body of these functions.
Thanks!
jingpan
Hi Pavlin,
The source code of these library does not open to customer. You can only use them.
Jing
