HTTP Client in C through MQX
renak
Hi All,
   I want to call a Restful JSON webservice using C through MQX.
Is there any HTTP client library ported in MQX which can be used for this?
Tags (4)
soledad
Hi Ren,
Sorry but there is not support for JSON request in RTCS. :smileysad:
Sol
renak
Ok...thank you for the information.
But, in case if it is NOT json, is it possible?
I mean, how to call a simple web service using C through MQX?
soledad
Please check the attachment and let me know if this helps :smileywink:
Sol
renak
Thank you for your help, but unfortunately the attachment din't help.
Let me explain my need in simple sentences.
We need to call a url (webservice) from TWRK60F120M.
We are using CodeWarrior as IDE.
Could you please help me in this regard?
Can you please provide some links which can guide us to get a solution?
danielchai
Senior Contributor I
