Document for web_hvac demo?
已解决
跳至解决方案
2,803 次查看
danielchai
Senior Contributor I
I am trying to develop a web server  and put all the web page files in the SD card. But  when I read MQXRTCS.pdf, there is no enough information about it.
And then I read the code in web_hvac, but still  can not understand it.
Is there a document about this?
Thanks.
1 解答
2,488 次查看
ZhangJennie
The explanation on how to run the web_hvac example is described in the MQX RTOS—Lab Tutorials document. This document can be found in the following link:
http://www.freescale.com/files/soft_dev_tools/doc/support_info/MQXTUTORIALLAB.pdf?fpsp=1
please check the attachment you can find two documents: The MQX from Zero doc is an introduction to the HVAC Demo, And the AN3907 I
在原帖中查看解决方案
1 回复
2,489 次查看
ZhangJennie
