Can we reduce timeout when transmit UDP packet
isaotakashima
We want to reduce timeout from 180 seconds to 10 seconds when transmit UDP packet.
I understood that they can reduce to 10 seconds by modify RTCSCFG_ARPTIME_EXPIRE_INCOMPLETE as below.
    #define RTCSCFG_ARPTIME_EXPIRE_INCOMPLETE    10000L   /* Change to 10 sec from 180000L  3 min */
Does this change cause any problem?
Could you please let us know minimum timeout value.
Please reply as soon as possible.
Takashima
DavidS
Hi Takashima,
It is OK to change that #define to shorter time.
David
isaotakashima
Dear David,
Thank you for your quick reply.
I understood that I can change that #define to shorter time.
Do you have specific minimum short time?
Takashima
DavidS
Hi Takashima,
It is application dependent so set it to what works for your application.
David
