Broadcasting
Broadcasting
2,709件の閲覧回数
Eng_crodrigo
Does anyone have an example of a Broadcasting (send/recv) on coldFire 5225X?
タグ(1)
2 返答(返信)
1,445件の閲覧回数
iaccy
My guess is that to broadcast, you just send to (on UDP) to IP adress 255.255.255.255. Anything broadcast on the port you opened will recv.
1,445件の閲覧回数
Eng_crodrigo
hi,
Yes, I did it before, its working, the problem was: i received my UDP pack back, because i had a UDP sock opened, than, i just get off this pack from my fifo.
Thank You.
Eng. Clóvis
