About HTTP Server Authentication
ソリューションへジャンプ
2,330件の閲覧回数
doron2006
I'm trying to get Basic Authentication working with MQX 4.0 and CW10.3 I followed the advice from HTTP Server Authentication
but I can´t understand point 2 of the explanation:
2. Add to my project authentification callback function like this:
int _http_auth_internal (HTTPD_SESSION_STRUCT* session){  // check user login  if (strncmp(session->request.auth, your_login, YOUR_LOGIN_SIZE) != 0)    return 1;  // check user password  if (strncmp(session->request.authPasswd, your_pass, YOUR_PASSWORD_SIZE) != 0)    return 1;  // all good  return 0;}
And attach this callback with
HTTPD_SET_PARAM_AUTH_FN(server, _http_auth_internal);
I appreciate any sample code that clear that concept. Thank you in advance Doron.
タグ(2)
2,004件の閲覧回数
pbanta
You need to write your own authentication function and then insert a pointer to that function into a table that the http server will use when it's time to perform authentication.
/*FUNCTION*------------------------------------------------------
* Function Name  : _http_auth_internal()
* Returned Value : 0 if successful, non-zero for error
* Comments       :
*     Performs authentication against authorized user list.
*END*-----------------------------------------------------------*/
int_32 _http_auth_internal (HTTPD_SESSION_STRUCT* session)
    int_32 retval = 1;
    char password[LCEUM_MAX_PASSWORD_SIZE + 1];
    uint_32 index;
    uint_32 result;
    index = lceum_get_index_for_username(session->request.auth);
    if (index > 0){
        result = lceum_get_password(index, password);
        if (result == LCEUM_OK){
            if (strncmp(password, session->request.authPasswd, (LCEUM_MAX_PASSWORD_SIZE)) != 0){
                retval = 1;  // invalid
            else{
                retval = 0;  // valid
    return retval;
* Function Name  : httpd_server_task()
* Returned Value : 0 if OK, other value if error
* Comments       :
*     HTTPD Server Task
_mqx_int httpd_server_task()
    extern const HTTPD_CGI_LINK_STRUCT guardian_cgi_lnk_tbl[];
    extern const TFS_DIR_ENTRY tfs_data[];
    uint_32 error;
    error = _io_tfs_install("tfs:", tfs_data);
    if (error == 0) {
        server = (HTTPD_STRUCT *)httpd_server_init((HTTPD_ROOT_DIR_STRUCT *)root_dir, "\\index.html");
        if (server != NULL) {
            HTTPD_SET_PARAM_CGI_TBL(server, (HTTPD_CGI_LINK_STRUCT*)guardian_cgi_lnk_tbl);
            /* Needed for authentication */
            httpd_server_run(server);
        else {
            error = -1;
    return(error);
At some point in your init sequence you need to call httpd_server_task().  (Or whatever name you give to it.)
   /* Start the http server */
   error = httpd_server_task();
Good luck.
2,005件の閲覧回数
pbanta
* Comments       :
    int_32 retval = 1;
    uint_32 index;
    uint_32 result;
    if (index > 0){
            else{
    return retval;
* Comments       :
*     HTTPD Server Task
    uint_32 error;
    if (error == 0) {
        else {
            error = -1;
    return(error);
Good luck.
