Freescale MQX™ 4.1 GA Release
The new Freescale MQX™ 4.1 GA release is now available on the www.freescale.com/MQX
·         Files available
Name
Description
1
FSL_MQX_RELEASE_NOTES_4_1_0
Freescale   MQX™ RTOS 4.1 Release Notes
2
Freescale   MQX RTOS 4.1
MQX™    Source code. Includes an RTOS, File System, TCP/IP and USB host/device   software stacks.
·         What is New?
o   New Board Support Package added
§  TWR-K21F120M
o   Vybrid-based board support packages for TWR-VF65GS10 and AutoEVB updated
§  Support of audio-related drivers extended--SAI, eSAI, and ASRC. Device driver for DSP Codec CS422888 added (AutoEVB only).
§  Support the Quadrature Decoder functionality in the FTM peripheral
§  Added eDMA driver
§  UART driver updated to use the eDMA
§  Clock management component ported
§  Added DCU driver
§  QSPI driver updated to support the FlashX framework
§  NAND FFS support added
o   DMA support in device drivers has been extended
§  Introduced new DMA device driver, supporting eDMA peripheral on Kinetis and Vybrid processor families
§  The SPI device driver was updated to support the new DMA driver
§  The SAI and eSAI audio drivers support DMA
§  eSDHC drivers were reworked to fully leverage the ADMA peripheral module
o   Driver updates
§  The LWADC driver has been ported to all supported board support packages. The support of the legacy ADC driver was discontinued.
§  The RTC driver was updated on all supported platforms. Provided generic, POSIX compatible API for time conversion functionality.
§  FlashX driver extended by handling Flash Swap functionality on Kinetis processors.
§  LP Timer module was added to the HW Timer framework. Its usage is demonstrated in the Low Power and HW Timer example applications
o   Standardization effort
§  Legacy MQX custom integer types were replaced by the Standard C99 set (int_32 -> int32_t, boolean -> bool, etc). A header file is provided with the set of backward compatible type definitions to make the transition to the new types easier. For more details, see Section 3.1 “C99 Types” in the Getting Started with Freescale MQX™ RTOS (document MQXGSRTOS).
§  The endian conversion macros were consolidated inside MQX. The htons, ntons and similar conversion functions were renamed to mqx_htons, mqx_nton to avoid a conflict with the standard.
o   NAND FFS library is no longer provided as a separate add in package but it is directly included as a part of MQX main package
o   RTCS new features and enhancements
§  The MQX TCP/IP stack is now available with an optional package to enable the IPv6 protocol support. For more information visit freescale.com/mqx.
§  The FTP server was redesigned to provide faster and more stable implementation.
§  The DNS resolver was updated.
o   USB
§  Fixed several EHCI related bugs (HUB, pipe close, audio example)
o   MQX startup is now split in two parts to avoid a crash risk if an interrupt occurs during the startup.
§  _bsp_enable_card() function has been replaced by the _bsp_pre_init() function that handles initialization of the OS vital functions, such as the timer (system tick), interrupt controller, memory management, etc. The _bsp_pre_init() function is called during the MQX initialization time, before any user task is created and the scheduler is not started.
§  The second part of the startup is done in a separate _mqx_init_task that executes _bsp_init() function for I/O drivers or stacks initialization and _bsp_post_init() function for possible post-init operations. After the _bsp_post_init() function execution, the _mqx_init_task is destroyed.
o   All BSPs are now adjusted to this concept. All I/O drivers are installed in the context of the _mqx_init_task after the MQX scheduler is started. This concept also allows a complex driver installation (handling ISRs during the driver initialization, drivers can use blocking functionality like _time_delay, etc.).
·         Known issues
o   For known issues and limitations please consult the release notes.
%3CLINGO-SUB%20id%3D%22lingo-sub-1106486%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EFreescale%20MQX%E2%84%A2%204.1%20GA%E3%83%AA%E3%83%AA%E3%83%BC%E3%82%B9%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1106486%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CDIV%20class%3D%22WordSection1%22%3E%3CP%20class%3D%22MsoNormal%22%3E%20%E6%96%B0%E3%81%97%E3%81%84Freescale%20MQX%E2%84%A2%204.1%20GA%E3%83%AA%E3%83%AA%E3%83%BC%E3%82%B9%E3%81%8C%E3%83%AA%E3%83%AA%E3%83%BC%E3%82%B9%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%20%3CA%20href%3D%22http%3A%2F%2Fwww.freescale.com%2FMQX%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3Ewww.freescale.com%2FMQX%3C%2FA%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%3E%3C%2FP%3E%3CP%20class%3D%22MsoListParagraph%22%20style%3D%22text-indent%3A%20-.25in%3B%20mso-list%3A%20l0%20level1%20lfo1%3B%22%3E%3CSPAN%20style%3D%22mso-bidi-font-family%3A%20Symbol%3B%20mso-bidi-font-weight%3A%20bold%3B%20mso-list%3A%20Ignore%3B%20font-family%3A%20Symbol%3B%20mso-fareast-font-family%3A%20Symbol%3B%22%3E%E3%83%BB%3CSPAN%20style%3D%22font%3A%207.0pt%20'Times%20New%20Roman'%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSTRONG%3E%E5%88%A9%E7%94%A8%E5%8F%AF%E8%83%BD%E3%81%AA%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%3C%2FSTRONG%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%3E%3C%2FP%3E%3CTABLE%20border%3D%220%22%20cellpadding%3D%220%22%20cellspacing%3D%220%22%20class%3D%22MsoNormalTable%22%20style%3D%22WIDTH%3A%20761px%3B%20BORDER-COLLAPSE%3A%20collapse%3B%20MARGIN-LEFT%3A%20-1.15pt%3B%20mso-yfti-tbllook%3A%201184%3B%20mso-padding-alt%3A%200in%200in%200in%200in%3B%22%3E%3CTBODY%3E%3CTR%20style%3D%22mso-yfti-irow%3A%200%3B%20mso-yfti-firstrow%3A%20yes%3B%20height%3A%2013.85pt%3B%22%3E%20%3CTD%20style%3D%22width%3A%2028.85pt%3B%20border%3A%20solid%20windowtext%201.0pt%3B%20%20%20background%3A%20black%3B%20padding%3A%200in%205.4pt%200in%205.4pt%3B%20height%3A%2013.85pt%3B%22%20valign%3D%22top%22%20width%3D%2238%22%3E%20%3CP%20align%3D%22center%22%20class%3D%22MsoNormal%22%20style%3D%22text-align%3A%20center%3B%22%3E%3CA%20name%3D%22RANGE!B6%3AD12%22%20target%3D%22_blank%22%3E%3C%2FA%3E%3CSTRONG%20style%3D%22color%3A%20white%3B%20font-size%3A%208.0pt%3B%20font-family%3A%20'Arial'%2C'sans-serif'%3B%22%3E%23%3C%2FSTRONG%3E%3C%2FP%3E%20%3C%2FTD%3E%20%3CTD%20style%3D%22width%3A%20195.6pt%3B%20border%3A%20solid%20windowtext%201.0pt%3B%20%20%20border-left%3A%20none%3B%20background%3A%20black%3B%20padding%3A%200in%205.4pt%200in%205.4pt%3B%20height%3A%2013.85pt%3B%22%20valign%3D%22top%22%20width%3D%22261%22%3E%20%3CP%20align%3D%22center%22%20class%3D%22MsoNormal%22%20style%3D%22text-align%3A%20center%3B%22%3E%3CSTRONG%20style%3D%22color%3A%20white%3B%20font-size%3A%208.0pt%3B%20font-family%3A%20'Arial'%2C'sans-serif'%3B%22%3E%E5%90%8D%E7%A7%B0%20%3C%2FSTRONG%3E%3C%2FP%3E%20%3C%2FTD%3E%20%3CTD%20style%3D%22width%3A%20346.3pt%3B%20border%3A%20solid%20windowtext%201.0pt%3B%20%20%20border-left%3A%20none%3B%20background%3A%20black%3B%20padding%3A%200in%205.4pt%200in%205.4pt%3B%20height%3A%2013.85pt%3B%22%20valign%3D%22top%22%20width%3D%22462%22%3E%20%3CP%20align%3D%22center%22%20class%3D%22MsoNormal%22%20style%3D%22text-align%3A%20center%3B%22%3E%3CSTRONG%20style%3D%22color%3A%20white%3B%20font-size%3A%208.0pt%3B%20font-family%3A%20'Arial'%2C'sans-serif'%3B%22%3E%E5%BD%A2%E5%AE%B9%3C%2FSTRONG%3E%3C%2FP%3E%20%3C%2FTD%3E%3C%2FTR%3E%3CTR%20style%3D%22mso-yfti-irow%3A%201%3B%20height%3A%2028.25pt%3B%22%3E%20%3CTD%20style%3D%22width%3A%2028.85pt%3B%20border%3A%20solid%20windowtext%201.0pt%3B%20%20%20border-top%3A%20none%3B%20padding%3A%200in%205.4pt%200in%205.4pt%3B%20height%3A%2028.25pt%3B%22%20valign%3D%22top%22%20width%3D%2238%22%3E%20%3CP%20align%3D%22center%22%20class%3D%22MsoNormal%22%20style%3D%22text-align%3A%20center%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20'Arial'%2C'sans-serif'%3B%22%3E1%3C%2FSPAN%3E%3C%2FP%3E%20%3C%2FTD%3E%20%3CTD%20style%3D%22width%3A%20195.6pt%3B%20border-top%3A%20none%3B%20border-left%3A%20%20%20none%3B%20border-bottom%3A%20solid%20windowtext%201.0pt%3B%20border-right%3A%20solid%20windowtext%201.0pt%3B%20%20%20padding%3A%200in%205.4pt%200in%205.4pt%3B%20height%3A%2028.25pt%3B%22%20valign%3D%22top%22%20width%3D%22261%22%3E%20%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%2012.0pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20%20%20font-family%3A%20'Arial'%2C'sans-serif'%3B%22%3E%3CA%20href%3D%22http%3A%2F%2Fcache.freescale.com%2Ffiles%2Fsoft_dev_tools%2Fdoc%2Fsupport_info%2FMQX_Release_Notes.pdf%3Ffpsp%3D1%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3EFSL_MQX_RELEASE_NOTES_4_1_0%3C%2FA%3E%3C%2FSPAN%3E%3C%2FP%3E%20%3C%2FTD%3E%20%3CTD%20style%3D%22width%3A%20346.3pt%3B%20border-top%3A%20none%3B%20border-left%3A%20%20%20none%3B%20border-bottom%3A%20solid%20windowtext%201.0pt%3B%20border-right%3A%20solid%20windowtext%201.0pt%3B%20%20%20padding%3A%200in%205.4pt%200in%205.4pt%3B%20height%3A%2028.25pt%3B%22%20valign%3D%22top%22%20width%3D%22462%22%3E%20%3CP%20class%3D%22MsoNormal%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20'Arial'%2C'sans-serif'%3B%22%3E%E3%83%95%E3%83%AA%E3%83%BC%E3%82%B9%E3%82%B1%E3%83%BC%E3%83%ABMQX%E2%84%A2%20RTOS%204.1%E3%83%AA%E3%83%AA%E3%83%BC%E3%82%B9%E3%83%BB%E3%83%8E%E3%83%BC%E3%83%88%3C%2FSPAN%3E%3C%2FP%3E%20%3C%2FTD%3E%3C%2FTR%3E%3CTR%20style%3D%22mso-yfti-irow%3A%202%3B%20mso-yfti-lastrow%3A%20yes%3B%20height%3A%2026.0pt%3B%22%3E%20%3CTD%20style%3D%22width%3A%2028.85pt%3B%20border%3A%20solid%20windowtext%201.0pt%3B%20%20%20border-top%3A%20none%3B%20padding%3A%200in%205.4pt%200in%205.4pt%3B%20height%3A%2026.0pt%3B%22%20valign%3D%22top%22%20width%3D%2238%22%3E%20%3CP%20align%3D%22center%22%20class%3D%22MsoNormal%22%20style%3D%22text-align%3A%20center%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20'Arial'%2C'sans-serif'%3B%22%3E2%3C%2FSPAN%3E%3C%2FP%3E%20%3C%2FTD%3E%20%3CTD%20style%3D%22width%3A%20195.6pt%3B%20border-top%3A%20none%3B%20border-left%3A%20%20%20none%3B%20border-bottom%3A%20solid%20windowtext%201.0pt%3B%20border-right%3A%20solid%20windowtext%201.0pt%3B%20%20%20padding%3A%200in%205.4pt%200in%205.4pt%3B%20height%3A%2026.0pt%3B%22%20valign%3D%22top%22%20width%3D%22261%22%3E%20%3CP%20class%3D%22MsoNormal%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20'Arial'%2C'sans-serif'%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fwww.freescale.com%2Fwebapp%2FDownload%3FcolCode%3DFSLMQXOS_4_1_0_BSP%26amp%3BappType%3Dlicense%26amp%3Blocation%3Dnull%26amp%3Bfpsp%3D1%26amp%3BWT_TYPE%3DOperating%2520Systems%26amp%3BWT_VENDOR%3DFREESCALE%26amp%3BWT_FILE_FORMAT%3Dexe%26amp%3BWT_ASSET%3DDownloads%26amp%3Bsr%3D11%26amp%3BParent_nodeId%3D1228773250613737641153%26amp%3BParent_pageType%3Dproduct%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3E%E3%83%95%E3%83%AA%E3%83%BC%E3%82%B9%E3%82%B1%E3%83%BC%E3%83%ABMQX%20RTOS%204.1%3C%2FA%3E%3C%2FSPAN%3E%3C%2FP%3E%20%3C%2FTD%3E%20%3CTD%20style%3D%22width%3A%20346.3pt%3B%20border-top%3A%20none%3B%20border-left%3A%20%20%20none%3B%20border-bottom%3A%20solid%20windowtext%201.0pt%3B%20border-right%3A%20solid%20windowtext%201.0pt%3B%20%20%20padding%3A%200in%205.4pt%200in%205.4pt%3B%20height%3A%2026.0pt%3B%22%20valign%3D%22top%22%20width%3D%22462%22%3E%20%3CP%20class%3D%22MsoNormal%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20'Arial'%2C'sans-serif'%3B%22%3EMQX%E2%84%A2%E3%82%BD%E3%83%BC%E3%82%B9%E3%82%B3%E3%83%BC%E3%83%89%E3%80%82RTOS%E3%80%81%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%80%81TCP%2FIP%E3%80%81USB%E3%83%9B%E3%82%B9%E3%83%88%2F%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%82%BD%E3%83%95%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A2%E3%82%B9%E3%82%BF%E3%83%83%E3%82%AF%E3%81%8C%E5%90%AB%E3%81%BE%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%20%3C%2FSPAN%3E%3C%2FP%3E%20%3C%2FTD%3E%3C%2FTR%3E%3C%2FTBODY%3E%3C%2FTABLE%3E%3CP%20class%3D%22MsoNormal%22%3E%3C%2FP%3E%3CP%20class%3D%22MsoListParagraph%22%20style%3D%22text-indent%3A%20-.25in%3B%20mso-list%3A%20l0%20level1%20lfo1%3B%22%3E%3CSPAN%20style%3D%22mso-bidi-font-family%3A%20Symbol%3B%20mso-bidi-font-weight%3A%20bold%3B%20mso-list%3A%20Ignore%3B%20font-family%3A%20Symbol%3B%20mso-fareast-font-family%3A%20Symbol%3B%22%3E%E3%83%BB%3CSPAN%20style%3D%22font%3A%207.0pt%20'Times%20New%20Roman'%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSTRONG%3E%E6%96%B0%E7%9D%80%E6%83%85%E5%A0%B1%E3%81%A8%E3%81%AF%3F%3C%2FSTRONG%3E%3C%2FP%3E%3CP%20class%3D%22MsoListParagraph%22%20style%3D%22margin-left%3A%201.0in%3B%20text-indent%3A%20-.25in%3B%20mso-list%3A%20l0%20level2%20lfo1%3B%22%3E%3CSPAN%20style%3D%22mso-list%3A%20Ignore%3B%20mso-ansi-language%3A%20IT%3B%20font-family%3A%20'Courier%20New'%3B%20mso-fareast-font-family%3A%20'Courier%20New'%3B%22%3Eo%3CSPAN%20style%3D%22font%3A%207.0pt%20'Times%20New%20Roman'%3B%22%3E%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20lang%3D%22IT%22%20style%3D%22mso-ansi-language%3A%20IT%3B%22%3E%E6%96%B0%E3%81%97%E3%81%84%E3%83%9C%E3%83%BC%E3%83%89%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%83%91%E3%83%83%E3%82%B1%E3%83%BC%E3%82%B8%E3%81%8C%E8%BF%BD%E5%8A%A0%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoListParagraph%22%20style%3D%22margin-left%3A%201.5in%3B%20text-indent%3A%20-.25in%3B%20mso-list%3A%20l0%20level3%20lfo1%3B%22%3E%3CSPAN%20style%3D%22mso-bidi-font-family%3A%20Wingdings%3B%20mso-list%3A%20Ignore%3B%20mso-ansi-language%3A%20IT%3B%20font-family%3A%20Wingdings%3B%20mso-fareast-font-family%3A%20Wingdings%3B%22%3E%C2%A7%3CSPAN%20style%3D%22font%3A%207.0pt%20'Times%20New%20Roman'%3B%22%3E%26nbsp%3B%20%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20lang%3D%22IT%22%20style%3D%22mso-ansi-language%3A%20IT%3B%22%3ETWR-K21F120M%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoListParagraph%22%20style%3D%22margin-left%3A%201.0in%3B%20text-indent%3A%20-.25in%3B%20mso-list%3A%20l0%20level2%20lfo1%3B%22%3E%3CSPAN%20style%3D%22mso-list%3A%20Ignore%3B%20mso-ansi-language%3A%20IT%3B%20font-family%3A%20'Courier%20New'%3B%20mso-fareast-font-family%3A%20'Courier%20New'%3B%22%3Eo%3CSPAN%20style%3D%22font%3A%207.0pt%20'Times%20New%20Roman'%3B%22%3E%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20lang%3D%22IT%22%20style%3D%22mso-ansi-language%3A%20IT%3B%22%3ETWR-VF65GS10%E3%81%8A%E3%82%88%E3%81%B3AutoEVB%E7%94%A8%E3%81%AEVybrid%E3%83%99%E3%83%BC%E3%82%B9%E3%81%AE%E3%83%9C%E3%83%BC%E3%83%89%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%83%91%E3%83%83%E3%82%B1%E3%83%BC%E3%82%B8%E3%82%92%E6%9B%B4%E6%96%B0%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoListParagraph%22%20style%3D%22margin-left%3A%201.5in%3B%20text-indent%3A%20-.25in%3B%20mso-list%3A%20l0%20level3%20lfo1%3B%22%3E%3CSPAN%20style%3D%22mso-bidi-font-family%3A%20Wingdings%3B%20mso-list%3A%20Ignore%3B%20mso-ansi-language%3A%20IT%3B%20font-family%3A%20Wingdings%3B%20mso-fareast-font-family%3A%20Wingdings%3B%22%3E%C2%A7%3CSPAN%20style%3D%22font%3A%207.0pt%20'Times%20New%20Roman'%3B%22%3E%26nbsp%3B%20%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20lang%3D%22IT%22%20style%3D%22mso-ansi-language%3A%20IT%3B%22%3E%E3%82%AA%E3%83%BC%E3%83%87%E3%82%A3%E3%82%AA%E9%96%A2%E9%80%A3%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%20(SAI%E3%80%81ESAI%E3%80%81ASRC)%20%E3%81%AE%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%8C%E6%8B%A1%E5%BC%B5%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82DSP%20%E3%82%B3%E3%83%BC%E3%83%87%E3%83%83%E3%82%AF%E7%94%A8%E3%81%AE%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%20%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%20CS422888%E8%BF%BD%E5%8A%A0%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%20(AutoEVB%20%E3%81%AE%E3%81%BF)%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoListParagraph%22%20style%3D%22margin-left%3A%201.5in%3B%20text-indent%3A%20-.25in%3B%20mso-list%3A%20l0%20level3%20lfo1%3B%22%3E%3CSPAN%20style%3D%22mso-bidi-font-family%3A%20Wingdings%3B%20mso-list%3A%20Ignore%3B%20mso-ansi-language%3A%20IT%3B%20font-family%3A%20Wingdings%3B%20mso-fareast-font-family%3A%20Wingdings%3B%22%3E%C2%A7%3CSPAN%20style%3D%22font%3A%207.0pt%20'Times%20New%20Roman'%3B%22%3E%26nbsp%3B%20%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20lang%3D%22IT%22%20style%3D%22mso-ansi-language%3A%20IT%3B%22%3EFTM%E3%83%9A%E3%83%AA%E3%83%95%E3%82%A7%E3%83%A9%E3%83%AB%E3%81%AE%E7%9B%B4%E4%BA%A4%E3%83%87%E3%82%B3%E3%83%BC%E3%83%80%E3%83%BC%E6%A9%9F%E8%83%BD%E3%82%92%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoListParagraph%22%20style%3D%22margin-left%3A%201.5in%3B%20text-indent%3A%20-.25in%3B%20mso-list%3A%20l0%20level3%20lfo1%3B%22%3E%3CSPAN%20style%3D%22mso-bidi-font-family%3A%20Wingdings%3B%20mso-list%3A%20Ignore%3B%20mso-ansi-language%3A%20IT%3B%20font-family%3A%20Wingdings%3B%20mso-fareast-font-family%3A%20Wingdings%3B%22%3E%C2%A7%3CSPAN%20style%3D%22font%3A%207.0pt%20'Times%20New%20Roman'%3B%22%3E%26nbsp%3B%20%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20lang%3D%22IT%22%20style%3D%22mso-ansi-language%3A%20IT%3B%22%3EeDMA%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%82%92%E8%BF%BD%E5%8A%A0%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoListParagraph%22%20style%3D%22margin-left%3A%201.5in%3B%20text-indent%3A%20-.25in%3B%20mso-list%3A%20l0%20level3%20lfo1%3B%22%3E%3CSPAN%20style%3D%22mso-bidi-font-family%3A%20Wingdings%3B%20mso-list%3A%20Ignore%3B%20mso-ansi-language%3A%20IT%3B%20font-family%3A%20Wingdings%3B%20mso-fareast-font-family%3A%20Wingdings%3B%22%3E%C2%A7%3CSPAN%20style%3D%22font%3A%207.0pt%20'Times%20New%20Roman'%3B%22%3E%26nbsp%3B%20%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20lang%3D%22IT%22%20style%3D%22mso-ansi-language%3A%20IT%3B%22%3EEDMA%20%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E3%82%88%E3%81%86%E3%81%AB%E6%9B%B4%E6%96%B0%E3%81%95%E3%82%8C%E3%81%9F%20UART%20%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoListParagraph%22%20style%3D%22margin-left%3A%201.5in%3B%20text-indent%3A%20-.25in%3B%20mso-list%3A%20l0%20level3%20lfo1%3B%22%3E%3CSPAN%20style%3D%22mso-bidi-font-family%3A%20Wingdings%3B%20mso-list%3A%20Ignore%3B%20mso-ansi-language%3A%20IT%3B%20font-family%3A%20Wingdings%3B%20mso-fareast-font-family%3A%20Wingdings%3B%22%3E%C2%A7%3CSPAN%20style%3D%22font%3A%207.0pt%20'Times%20New%20Roman'%3B%22%3E%26nbsp%3B%20%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20lang%3D%22IT%22%20style%3D%22mso-ansi-language%3A%20IT%3B%22%3E%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%E7%AE%A1%E7%90%86%E3%82%B3%E3%83%B3%E3%83%9D%E3%83%BC%E3%83%8D%E3%83%B3%E3%83%88%E7%A7%BB%E6%A4%8D%E6%B8%88%E3%81%BF%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoListParagraph%22%20style%3D%22margin-left%3A%201.5in%3B%20text-indent%3A%20-.25in%3B%20mso-list%3A%20l0%20level3%20lfo1%3B%22%3E%3CSPAN%20style%3D%22mso-bidi-font-family%3A%20Wingdings%3B%20mso-list%3A%20Ignore%3B%20mso-ansi-language%3A%20IT%3B%20font-family%3A%20Wingdings%3B%20mso-fareast-font-family%3A%20Wingdings%3B%22%3E%C2%A7%3CSPAN%20style%3D%22font%3A%207.0pt%20'Times%20New%20Roman'%3B%22%3E%26nbsp%3B%20%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20lang%3D%22IT%22%20style%3D%22mso-ansi-language%3A%20IT%3B%22%3EDCU%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%82%92%E8%BF%BD%E5%8A%A0%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoListParagraph%22%20style%3D%22margin-left%3A%201.5in%3B%20text-indent%3A%20-.25in%3B%20mso-list%3A%20l0%20level3%20lfo1%3B%22%3E%3CSPAN%20style%3D%22mso-bidi-font-family%3A%20Wingdings%3B%20mso-list%3A%20Ignore%3B%20mso-ansi-language%3A%20IT%3B%20font-family%3A%20Wingdings%3B%20mso-fareast-font-family%3A%20Wingdings%3B%22%3E%C2%A7%3CSPAN%20style%3D%22font%3A%207.0pt%20'Times%20New%20Roman'%3B%22%3E%26nbsp%3B%20%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20lang%3D%22IT%22%20style%3D%22mso-ansi-language%3A%20IT%3B%22%3EFlashX%20%E3%83%95%E3%83%AC%E3%83%BC%E3%83%A0%E3%83%AF%E3%83%BC%E3%82%AF%E3%82%92%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%99%E3%82%8B%E3%82%88%E3%81%86%E3%81%AB%E6%9B%B4%E6%96%B0%E3%81%95%E3%82%8C%E3%81%9F%20QSPI%20%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoListParagraph%22%20style%3D%22margin-left%3A%201.5in%3B%20text-indent%3A%20-.25in%3B%20mso-list%3A%20l0%20level3%20lfo1%3B%22%3E%3CSPAN%20style%3D%22mso-bidi-font-family%3A%20Wingdings%3B%20mso-list%3A%20Ignore%3B%20mso-ansi-language%3A%20IT%3B%20font-family%3A%20Wingdings%3B%20mso-fareast-font-family%3A%20Wingdings%3B%22%3E%C2%A7%3CSPAN%20style%3D%22font%3A%207.0pt%20'Times%20New%20Roman'%3B%22%3E%26nbsp%3B%20%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20lang%3D%22IT%22%20style%3D%22mso-ansi-language%3A%20IT%3B%22%3ENAND%20FFS%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%8C%E8%BF%BD%E5%8A%A0%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoListParagraph%22%20style%3D%22margin-left%3A%201.0in%3B%20text-indent%3A%20-.25in%3B%20mso-list%3A%20l0%20level2%20lfo1%3B%22%3E%3CSPAN%20style%3D%22mso-list%3A%20Ignore%3B%20mso-ansi-language%3A%20IT%3B%20font-family%3A%20'Courier%20New'%3B%20mso-fareast-font-family%3A%20'Courier%20New'%3B%22%3Eo%3CSPAN%20style%3D%22font%3A%207.0pt%20'Times%20New%20Roman'%3B%22%3E%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20lang%3D%22IT%22%20style%3D%22mso-ansi-language%3A%20IT%3B%22%3E%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%E3%81%A7%E3%81%AE%20DMA%20%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%8C%E6%8B%A1%E5%BC%B5%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoListParagraph%22%20style%3D%22margin-left%3A%201.5in%3B%20text-indent%3A%20-.25in%3B%20mso-list%3A%20l0%20level3%20lfo1%3B%22%3E%3CSPAN%20style%3D%22mso-bidi-font-family%3A%20Wingdings%3B%20mso-list%3A%20Ignore%3B%20mso-ansi-language%3A%20IT%3B%20font-family%3A%20Wingdings%3B%20mso-fareast-font-family%3A%20Wingdings%3B%22%3E%C2%A7%3CSPAN%20style%3D%22font%3A%207.0pt%20'Times%20New%20Roman'%3B%22%3E%26nbsp%3B%20%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20lang%3D%22IT%22%20style%3D%22mso-ansi-language%3A%20IT%3B%22%3EKinetis%E3%81%8A%E3%82%88%E3%81%B3Vybrid%E3%83%97%E3%83%AD%E3%82%BB%E3%83%83%E3%82%B5%E3%83%BB%E3%83%95%E3%82%A1%E3%83%9F%E3%83%AA%E3%81%AEeDMA%E3%83%9A%E3%83%AA%E3%83%95%E3%82%A7%E3%83%A9%E3%83%AB%E3%82%92%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%99%E3%82%8B%E6%96%B0%E3%81%97%E3%81%84DMA%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%83%BB%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%82%92%E7%99%BA%E8%A1%A8%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoListParagraph%22%20style%3D%22margin-left%3A%201.5in%3B%20text-indent%3A%20-.25in%3B%20mso-list%3A%20l0%20level3%20lfo1%3B%22%3E%3CSPAN%20style%3D%22mso-bidi-font-family%3A%20Wingdings%3B%20mso-list%3A%20Ignore%3B%20mso-ansi-language%3A%20IT%3B%20font-family%3A%20Wingdings%3B%20mso-fareast-font-family%3A%20Wingdings%3B%22%3E%C2%A7%3CSPAN%20style%3D%22font%3A%207.0pt%20'Times%20New%20Roman'%3B%22%3E%26nbsp%3B%20%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20lang%3D%22IT%22%20style%3D%22mso-ansi-language%3A%20IT%3B%22%3ESPI%20%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%20%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%E3%81%AF%E3%80%81%E6%96%B0%E3%81%97%E3%81%84%20DMA%20%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%E3%82%92%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%99%E3%82%8B%E3%82%88%E3%81%86%E3%81%AB%E6%9B%B4%E6%96%B0%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoListParagraph%22%20style%3D%22margin-left%3A%201.5in%3B%20text-indent%3A%20-.25in%3B%20mso-list%3A%20l0%20level3%20lfo1%3B%22%3E%3CSPAN%20style%3D%22mso-bidi-font-family%3A%20Wingdings%3B%20mso-list%3A%20Ignore%3B%20mso-ansi-language%3A%20IT%3B%20font-family%3A%20Wingdings%3B%20mso-fareast-font-family%3A%20Wingdings%3B%22%3E%C2%A7%3CSPAN%20style%3D%22font%3A%207.0pt%20'Times%20New%20Roman'%3B%22%3E%26nbsp%3B%20%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20lang%3D%22IT%22%20style%3D%22mso-ansi-language%3A%20IT%3B%22%3ESAI%20%E3%81%8A%E3%82%88%E3%81%B3%20eSAI%20%E3%82%AA%E3%83%BC%E3%83%87%E3%82%A3%E3%82%AA%20%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%E3%81%AF%20DMA%20%E3%82%92%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%97%E3%81%BE%E3%81%99%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoListParagraph%22%20style%3D%22margin-left%3A%201.5in%3B%20text-indent%3A%20-.25in%3B%20mso-list%3A%20l0%20level3%20lfo1%3B%22%3E%3CSPAN%20style%3D%22mso-bidi-font-family%3A%20Wingdings%3B%20mso-list%3A%20Ignore%3B%20mso-ansi-language%3A%20IT%3B%20font-family%3A%20Wingdings%3B%20mso-fareast-font-family%3A%20Wingdings%3B%22%3E%C2%A7%3CSPAN%20style%3D%22font%3A%207.0pt%20'Times%20New%20Roman'%3B%22%3E%26nbsp%3B%20%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20lang%3D%22IT%22%20style%3D%22mso-ansi-language%3A%20IT%3B%22%3EeSDHC%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%81%AF%E3%80%81ADMA%E3%83%9A%E3%83%AA%E3%83%95%E3%82%A7%E3%83%A9%E3%83%AB%E3%83%A2%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%AB%E3%82%92%E6%9C%80%E5%A4%A7%E9%99%90%E3%81%AB%E6%B4%BB%E7%94%A8%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AB%E4%BD%9C%E3%82%8A%E7%9B%B4%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoListParagraph%22%20style%3D%22margin-left%3A%201.0in%3B%20text-indent%3A%20-.25in%3B%20mso-list%3A%20l0%20level2%20lfo1%3B%22%3E%3CSPAN%20style%3D%22mso-list%3A%20Ignore%3B%20mso-ansi-language%3A%20IT%3B%20font-family%3A%20'Courier%20New'%3B%20mso-fareast-font-family%3A%20'Courier%20New'%3B%22%3Eo%3CSPAN%20style%3D%22font%3A%207.0pt%20'Times%20New%20Roman'%3B%22%3E%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20lang%3D%22IT%22%20style%3D%22mso-ansi-language%3A%20IT%3B%22%3E%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%E3%81%AE%E6%9B%B4%E6%96%B0%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoListParagraph%22%20style%3D%22margin-left%3A%201.5in%3B%20text-indent%3A%20-.25in%3B%20mso-list%3A%20l0%20level3%20lfo1%3B%22%3E%3CSPAN%20style%3D%22mso-bidi-font-family%3A%20Wingdings%3B%20mso-list%3A%20Ignore%3B%20mso-ansi-language%3A%20IT%3B%20font-family%3A%20Wingdings%3B%20mso-fareast-font-family%3A%20Wingdings%3B%22%3E%C2%A7%3CSPAN%20style%3D%22font%3A%207.0pt%20'Times%20New%20Roman'%3B%22%3E%26nbsp%3B%20%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20lang%3D%22IT%22%20style%3D%22mso-ansi-language%3A%20IT%3B%22%3ELWADC%20%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%E3%81%AF%E3%80%81%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%81%99%E3%81%B9%E3%81%A6%E3%81%AE%E3%83%9C%E3%83%BC%E3%83%89%20%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%20%E3%83%91%E3%83%83%E3%82%B1%E3%83%BC%E3%82%B8%E3%81%AB%E7%A7%BB%E6%A4%8D%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E5%BE%93%E6%9D%A5%E3%81%AEADC%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%E3%81%AE%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%AF%E7%B5%82%E4%BA%86%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoListParagraph%22%20style%3D%22margin-left%3A%201.5in%3B%20text-indent%3A%20-.25in%3B%20mso-list%3A%20l0%20level3%20lfo1%3B%22%3E%3CSPAN%20style%3D%22mso-bidi-font-family%3A%20Wingdings%3B%20mso-list%3A%20Ignore%3B%20mso-ansi-language%3A%20IT%3B%20font-family%3A%20Wingdings%3B%20mso-fareast-font-family%3A%20Wingdings%3B%22%3E%C2%A7%3CSPAN%20style%3D%22font%3A%207.0pt%20'Times%20New%20Roman'%3B%22%3E%26nbsp%3B%20%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20lang%3D%22IT%22%20style%3D%22mso-ansi-language%3A%20IT%3B%22%3ERTC%20%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%81%AF%E3%80%81%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%81%99%E3%81%B9%E3%81%A6%E3%81%AE%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%E3%81%A7%E6%9B%B4%E6%96%B0%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E6%99%82%E9%96%93%E5%A4%89%E6%8F%9B%E6%A9%9F%E8%83%BD%E7%94%A8%E3%81%AE%E6%B1%8E%E7%94%A8%20POSIX%20%E4%BA%92%E6%8F%9B%20API%20%E3%82%92%E6%8F%90%E4%BE%9B%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoListParagraph%22%20style%3D%22margin-left%3A%201.5in%3B%20text-indent%3A%20-.25in%3B%20mso-list%3A%20l0%20level3%20lfo1%3B%22%3E%3CSPAN%20style%3D%22mso-bidi-font-family%3A%20Wingdings%3B%20mso-list%3A%20Ignore%3B%20mso-ansi-language%3A%20IT%3B%20font-family%3A%20Wingdings%3B%20mso-fareast-font-family%3A%20Wingdings%3B%22%3E%C2%A7%3CSPAN%20style%3D%22font%3A%207.0pt%20'Times%20New%20Roman'%3B%22%3E%26nbsp%3B%20%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20lang%3D%22IT%22%20style%3D%22mso-ansi-language%3A%20IT%3B%22%3EFlashX%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%81%8C%E6%8B%A1%E5%BC%B5%E3%81%95%E3%82%8C%E3%80%81Kinetis%E3%83%97%E3%83%AD%E3%82%BB%E3%83%83%E3%82%B5%E3%81%A7Flash%20Swap%E6%A9%9F%E8%83%BD%E3%81%8C%E8%BF%BD%E5%8A%A0%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoListParagraph%22%20style%3D%22margin-left%3A%201.5in%3B%20text-indent%3A%20-.25in%3B%20mso-list%3A%20l0%20level3%20lfo1%3B%22%3E%3CSPAN%20style%3D%22mso-bidi-font-family%3A%20Wingdings%3B%20mso-list%3A%20Ignore%3B%20mso-ansi-language%3A%20IT%3B%20font-family%3A%20Wingdings%3B%20mso-fareast-font-family%3A%20Wingdings%3B%22%3E%C2%A7%3CSPAN%20style%3D%22font%3A%207.0pt%20'Times%20New%20Roman'%3B%22%3E%26nbsp%3B%20%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20lang%3D%22IT%22%20style%3D%22mso-ansi-language%3A%20IT%3B%22%3ELP%20Timer%20%E3%83%A2%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%AB%E3%81%8C%20HW%20Timer%20%E3%83%95%E3%83%AC%E3%83%BC%E3%83%A0%E3%83%AF%E3%83%BC%E3%82%AF%E3%81%AB%E8%BF%BD%E5%8A%A0%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%81%9D%E3%81%AE%E4%BD%BF%E7%94%A8%E6%B3%95%E3%81%AF%E3%80%81%E4%BD%8E%E9%9B%BB%E5%8A%9B%E3%81%8A%E3%82%88%E3%81%B3HW%E3%82%BF%E3%82%A4%E3%83%9E%E3%83%BC%E3%81%AE%E3%82%B5%E3%83%B3%E3%83%97%E3%83%AB%E3%82%A2%E3%83%97%E3%83%AA%E3%82%B1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%A7%E7%A4%BA%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoListParagraph%22%20style%3D%22margin-left%3A%201.0in%3B%20text-indent%3A%20-.25in%3B%20mso-list%3A%20l0%20level2%20lfo1%3B%22%3E%3CSPAN%20style%3D%22mso-list%3A%20Ignore%3B%20mso-ansi-language%3A%20IT%3B%20font-family%3A%20'Courier%20New'%3B%20mso-fareast-font-family%3A%20'Courier%20New'%3B%22%3Eo%3CSPAN%20style%3D%22font%3A%207.0pt%20'Times%20New%20Roman'%3B%22%3E%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20lang%3D%22IT%22%20style%3D%22mso-ansi-language%3A%20IT%3B%22%3E%E6%A8%99%E6%BA%96%E5%8C%96%E3%81%AE%E5%8F%96%E3%82%8A%E7%B5%84%E3%81%BF%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoListParagraph%22%20style%3D%22margin-left%3A%201.5in%3B%20text-indent%3A%20-.25in%3B%20mso-list%3A%20l0%20level3%20lfo1%3B%22%3E%3CSPAN%20style%3D%22mso-bidi-font-family%3A%20Wingdings%3B%20mso-list%3A%20Ignore%3B%20mso-ansi-language%3A%20IT%3B%20font-family%3A%20Wingdings%3B%20mso-fareast-font-family%3A%20Wingdings%3B%22%3E%C2%A7%3CSPAN%20style%3D%22font%3A%207.0pt%20'Times%20New%20Roman'%3B%22%3E%26nbsp%3B%20%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20lang%3D%22IT%22%20style%3D%22mso-ansi-language%3A%20IT%3B%22%3E%E5%BE%93%E6%9D%A5%E3%81%AE%20MQX%20%E3%82%AB%E3%82%B9%E3%82%BF%E3%83%A0%E6%95%B4%E6%95%B0%E5%9E%8B%E3%81%AF%E3%80%81%E6%A8%99%E6%BA%96%20C99%20%E3%82%BB%E3%83%83%E3%83%88%20(int_32%20-%26gt%3B%20int32_t%E3%80%81%E3%83%96%E3%83%BC%E3%83%AB%E5%80%A4%20-%26gt%3B%20bool%20%E3%81%AA%E3%81%A9)%20%E3%81%AB%E7%BD%AE%E3%81%8D%E6%8F%9B%E3%81%88%E3%82%89%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%83%98%E3%83%83%E3%83%80%E3%83%BC%20%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%AB%E3%81%AF%E3%80%81%E6%96%B0%E3%81%97%E3%81%84%E5%9E%8B%E3%81%B8%E3%81%AE%E7%A7%BB%E8%A1%8C%E3%82%92%E5%AE%B9%E6%98%93%E3%81%AB%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AE%E4%B8%8B%E4%BD%8D%E4%BA%92%E6%8F%9B%E6%80%A7%E3%81%AE%E3%81%82%E3%82%8B%E5%9E%8B%E5%AE%9A%E7%BE%A9%E3%81%AE%E3%82%BB%E3%83%83%E3%83%88%E3%81%8C%E7%94%A8%E6%84%8F%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E8%A9%B3%E7%B4%B0%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E3%81%AF%E3%80%81%E3%80%8EGetting%20Started%20with%20Freescale%20MQX%E2%84%A2%20RTOS%E3%80%8F(MQXGSRTOS)%E3%81%AE%E3%82%BB%E3%82%AF%E3%82%B7%E3%83%A7%E3%83%B33.1%E3%80%8CC99%E3%81%AE%E3%82%BF%E3%82%A4%E3%83%97%E3%80%8D%E3%82%92%E5%8F%82%E7%85%A7%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoListParagraph%22%20style%3D%22margin-left%3A%201.5in%3B%20text-indent%3A%20-.25in%3B%20mso-list%3A%20l0%20level3%20lfo1%3B%22%3E%3CSPAN%20style%3D%22mso-bidi-font-family%3A%20Wingdings%3B%20mso-list%3A%20Ignore%3B%20mso-ansi-language%3A%20IT%3B%20font-family%3A%20Wingdings%3B%20mso-fareast-font-family%3A%20Wingdings%3B%22%3E%C2%A7%3CSPAN%20style%3D%22font%3A%207.0pt%20'Times%20New%20Roman'%3B%22%3E%26nbsp%3B%20%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20lang%3D%22IT%22%20style%3D%22mso-ansi-language%3A%20IT%3B%22%3E%E3%82%A8%E3%83%B3%E3%83%87%E3%82%A3%E3%82%A2%E3%83%B3%E5%A4%89%E6%8F%9B%E3%83%9E%E3%82%AF%E3%83%AD%E3%81%AF%20MQX%20%E5%86%85%E3%81%AB%E7%B5%B1%E5%90%88%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82htons%E3%80%81ntons%E3%80%81%E3%81%8A%E3%82%88%E3%81%B3%E5%90%8C%E6%A7%98%E3%81%AE%E5%A4%89%E6%8F%9B%E9%96%A2%E6%95%B0%E3%81%AF%E3%80%81%E6%A8%99%E6%BA%96%E3%81%A8%E3%81%AE%E7%AB%B6%E5%90%88%E3%82%92%E9%81%BF%E3%81%91%E3%82%8B%E3%81%9F%E3%82%81%E3%81%ABmqx_nton%20mqx_htons%E3%81%AB%E5%90%8D%E5%89%8D%E3%81%8C%E5%A4%89%E6%9B%B4%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoListParagraph%22%20style%3D%22margin-left%3A%201.0in%3B%20text-indent%3A%20-.25in%3B%20mso-list%3A%20l0%20level2%20lfo1%3B%22%3E%3CSPAN%20style%3D%22mso-list%3A%20Ignore%3B%20mso-ansi-language%3A%20IT%3B%20font-family%3A%20'Courier%20New'%3B%20mso-fareast-font-family%3A%20'Courier%20New'%3B%22%3Eo%3CSPAN%20style%3D%22font%3A%207.0pt%20'Times%20New%20Roman'%3B%22%3E%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20lang%3D%22IT%22%20style%3D%22mso-ansi-language%3A%20IT%3B%22%3ENAND%20FFS%E3%83%A9%E3%82%A4%E3%83%96%E3%83%A9%E3%83%AA%E3%81%AF%E3%80%81%E5%80%8B%E5%88%A5%E3%81%AE%E3%82%A2%E3%83%89%E3%82%A4%E3%83%B3%E3%83%91%E3%83%83%E3%82%B1%E3%83%BC%E3%82%B8%E3%81%A8%E3%81%97%E3%81%A6%E6%8F%90%E4%BE%9B%E3%81%95%E3%82%8C%E3%81%AA%E3%81%8F%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8C%E3%80%81MQX%E3%83%A1%E3%82%A4%E3%83%B3%E3%83%91%E3%83%83%E3%82%B1%E3%83%BC%E3%82%B8%E3%81%AE%E4%B8%80%E9%83%A8%E3%81%A8%E3%81%97%E3%81%A6%E7%9B%B4%E6%8E%A5%E5%90%AB%E3%81%BE%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoListParagraph%22%20style%3D%22margin-left%3A%201.0in%3B%20text-indent%3A%20-.25in%3B%20mso-list%3A%20l0%20level2%20lfo1%3B%22%3E%3CSPAN%20style%3D%22mso-list%3A%20Ignore%3B%20mso-ansi-language%3A%20IT%3B%20font-family%3A%20'Courier%20New'%3B%20mso-fareast-font-family%3A%20'Courier%20New'%3B%22%3Eo%3CSPAN%20style%3D%22font%3A%207.0pt%20'Times%20New%20Roman'%3B%22%3E%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20lang%3D%22IT%22%20style%3D%22mso-ansi-language%3A%20IT%3B%22%3ERTCS%20%E3%81%AE%E6%96%B0%E6%A9%9F%E8%83%BD%E3%81%A8%E6%8B%A1%E5%BC%B5%E6%A9%9F%E8%83%BD%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoListParagraph%22%20style%3D%22margin-left%3A%201.5in%3B%20text-indent%3A%20-.25in%3B%20mso-list%3A%20l0%20level3%20lfo1%3B%22%3E%3CSPAN%20style%3D%22mso-bidi-font-family%3A%20Wingdings%3B%20mso-list%3A%20Ignore%3B%20mso-ansi-language%3A%20IT%3B%20font-family%3A%20Wingdings%3B%20mso-fareast-font-family%3A%20Wingdings%3B%22%3E%C2%A7%3CSPAN%20style%3D%22font%3A%207.0pt%20'Times%20New%20Roman'%3B%22%3E%26nbsp%3B%20%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20lang%3D%22IT%22%20style%3D%22mso-ansi-language%3A%20IT%3B%22%3EMQX%20TCP%2FIP%20%E3%82%B9%E3%82%BF%E3%83%83%E3%82%AF%E3%81%AF%E3%80%81IPv6%20%E3%83%97%E3%83%AD%E3%83%88%E3%82%B3%E3%83%AB%E3%83%BB%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%82%92%E6%9C%89%E5%8A%B9%E3%81%AB%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AE%E3%82%AA%E3%83%97%E3%82%B7%E3%83%A7%E3%83%B3%E3%83%BB%E3%83%91%E3%83%83%E3%82%B1%E3%83%BC%E3%82%B8%E3%81%A8%E3%81%A8%E3%82%82%E3%81%AB%E4%BD%BF%E7%94%A8%E3%81%A7%E3%81%8D%E3%82%8B%E3%82%88%E3%81%86%E3%81%AB%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E8%A9%B3%E7%B4%B0%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E3%81%AF%E3%80%81freescale.com%2Fmqx%20%E3%82%92%E3%81%94%E8%A6%A7%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoListParagraph%22%20style%3D%22margin-left%3A%201.5in%3B%20text-indent%3A%20-.25in%3B%20mso-list%3A%20l0%20level3%20lfo1%3B%22%3E%3CSPAN%20style%3D%22mso-bidi-font-family%3A%20Wingdings%3B%20mso-list%3A%20Ignore%3B%20mso-ansi-language%3A%20IT%3B%20font-family%3A%20Wingdings%3B%20mso-fareast-font-family%3A%20Wingdings%3B%22%3E%C2%A7%3CSPAN%20style%3D%22font%3A%207.0pt%20'Times%20New%20Roman'%3B%22%3E%26nbsp%3B%20%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20lang%3D%22IT%22%20style%3D%22mso-ansi-language%3A%20IT%3B%22%3EFTP%E3%82%B5%E3%83%BC%E3%83%90%E3%83%BC%E3%81%AF%E3%80%81%E3%82%88%E3%82%8A%E9%AB%98%E9%80%9F%E3%81%A7%E5%AE%89%E5%AE%9A%E3%81%97%E3%81%9F%E5%AE%9F%E8%A3%85%E3%82%92%E6%8F%90%E4%BE%9B%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AB%E5%86%8D%E8%A8%AD%E8%A8%88%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoListParagraph%22%20style%3D%22margin-left%3A%201.5in%3B%20text-indent%3A%20-.25in%3B%20mso-list%3A%20l0%20level3%20lfo1%3B%22%3E%3CSPAN%20style%3D%22mso-bidi-font-family%3A%20Wingdings%3B%20mso-list%3A%20Ignore%3B%20mso-ansi-language%3A%20IT%3B%20font-family%3A%20Wingdings%3B%20mso-fareast-font-family%3A%20Wingdings%3B%22%3E%C2%A7%3CSPAN%20style%3D%22font%3A%207.0pt%20'Times%20New%20Roman'%3B%22%3E%26nbsp%3B%20%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20lang%3D%22IT%22%20style%3D%22mso-ansi-language%3A%20IT%3B%22%3EDNS%20%E3%83%AA%E3%82%BE%E3%83%AB%E3%83%90%E3%83%BC%E3%81%8C%E6%9B%B4%E6%96%B0%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoListParagraph%22%20style%3D%22margin-left%3A%201.0in%3B%20text-indent%3A%20-.25in%3B%20mso-list%3A%20l0%20level2%20lfo1%3B%22%3E%3CSPAN%20style%3D%22mso-list%3A%20Ignore%3B%20mso-ansi-language%3A%20IT%3B%20font-family%3A%20'Courier%20New'%3B%20mso-fareast-font-family%3A%20'Courier%20New'%3B%22%3Eo%3CSPAN%20style%3D%22font%3A%207.0pt%20'Times%20New%20Roman'%3B%22%3E%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20lang%3D%22IT%22%20style%3D%22mso-ansi-language%3A%20IT%3B%22%3EUSB%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoListParagraph%22%20style%3D%22margin-left%3A%201.5in%3B%20text-indent%3A%20-.25in%3B%20mso-list%3A%20l0%20level3%20lfo1%3B%22%3E%3CSPAN%20style%3D%22mso-bidi-font-family%3A%20Wingdings%3B%20mso-list%3A%20Ignore%3B%20mso-ansi-language%3A%20IT%3B%20font-family%3A%20Wingdings%3B%20mso-fareast-font-family%3A%20Wingdings%3B%22%3E%C2%A7%3CSPAN%20style%3D%22font%3A%207.0pt%20'Times%20New%20Roman'%3B%22%3E%26nbsp%3B%20%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20lang%3D%22IT%22%20style%3D%22mso-ansi-language%3A%20IT%3B%22%3EEHCI%E9%96%A2%E9%80%A3%E3%81%AE%E3%81%84%E3%81%8F%E3%81%A4%E3%81%8B%E3%81%AE%E3%83%90%E3%82%B0%E3%82%92%E4%BF%AE%E6%AD%A3(HUB%E3%80%81%E3%83%91%E3%82%A4%E3%83%97%E3%82%AF%E3%83%AD%E3%83%BC%E3%82%BA%E3%80%81%E3%82%AA%E3%83%BC%E3%83%87%E3%82%A3%E3%82%AA%E4%BE%8B)%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoListParagraph%22%20style%3D%22margin-left%3A%201.0in%3B%20text-indent%3A%20-.25in%3B%20mso-list%3A%20l0%20level2%20lfo1%3B%22%3E%3CSPAN%20style%3D%22mso-list%3A%20Ignore%3B%20mso-ansi-language%3A%20IT%3B%20font-family%3A%20'Courier%20New'%3B%20mso-fareast-font-family%3A%20'Courier%20New'%3B%22%3Eo%3CSPAN%20style%3D%22font%3A%207.0pt%20'Times%20New%20Roman'%3B%22%3E%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20lang%3D%22IT%22%20style%3D%22mso-ansi-language%3A%20IT%3B%22%3EMQX%E3%81%AE%E8%B5%B7%E5%8B%95%E3%81%AF%E3%80%81%E8%B5%B7%E5%8B%95%E4%B8%AD%E3%81%AB%E5%89%B2%E3%82%8A%E8%BE%BC%E3%81%BF%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%97%E3%81%9F%E5%A0%B4%E5%90%88%E3%81%AE%E3%82%AF%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%83%BB%E3%83%AA%E3%82%B9%E3%82%AF%E3%82%92%E5%9B%9E%E9%81%BF%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AB%E3%80%812%E3%81%A4%E3%81%AE%E9%83%A8%E5%88%86%E3%81%AB%E5%88%86%E5%89%B2%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoListParagraph%22%20style%3D%22margin-left%3A%201.5in%3B%20text-indent%3A%20-.25in%3B%20mso-list%3A%20l0%20level3%20lfo1%3B%22%3E%3CSPAN%20style%3D%22mso-bidi-font-family%3A%20Wingdings%3B%20mso-list%3A%20Ignore%3B%20mso-ansi-language%3A%20IT%3B%20font-family%3A%20Wingdings%3B%20mso-fareast-font-family%3A%20Wingdings%3B%22%3E%C2%A7%3CSPAN%20style%3D%22font%3A%207.0pt%20'Times%20New%20Roman'%3B%22%3E%26nbsp%3B%20%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20lang%3D%22IT%22%20style%3D%22mso-ansi-language%3A%20IT%3B%22%3E_bsp_enable_card()%20%E9%96%A2%E6%95%B0%E3%81%AF%E3%80%81%E3%82%BF%E3%82%A4%E3%83%9E%E3%83%BC%20(%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%20%E3%83%86%E3%82%A3%E3%83%83%E3%82%AF)%E3%80%81%E5%89%B2%E3%82%8A%E8%BE%BC%E3%81%BF%E3%82%B3%E3%83%B3%E3%83%88%E3%83%AD%E3%83%BC%E3%83%A9%E3%83%BC%E3%80%81%E3%83%A1%E3%83%A2%E3%83%AA%E7%AE%A1%E7%90%86%E3%81%AA%E3%81%A9%E3%81%AE%20OS%20%E9%87%8D%E8%A6%81%E3%81%AA%E9%96%A2%E6%95%B0%E3%81%AE%E5%88%9D%E6%9C%9F%E5%8C%96%E3%82%92%E5%87%A6%E7%90%86%E3%81%99%E3%82%8B%20_bsp_pre_init()%20%E9%96%A2%E6%95%B0%E3%81%AB%E7%BD%AE%E3%81%8D%E6%8F%9B%E3%81%88%E3%82%89%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82_bsp_pre_init()%20%E9%96%A2%E6%95%B0%E3%81%AF%E3%80%81MQX%20%E5%88%9D%E6%9C%9F%E5%8C%96%E6%99%82%E9%96%93%E4%B8%AD%E3%80%81%E3%81%A4%E3%81%BE%E3%82%8A%E3%83%A6%E3%83%BC%E3%82%B6%E3%83%BC%E3%83%BB%E3%82%BF%E3%82%B9%E3%82%AF%E3%81%8C%E4%BD%9C%E6%88%90%E3%81%95%E3%82%8C%E3%80%81%E3%82%B9%E3%82%B1%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%A9%E3%83%BC%E3%81%8C%E9%96%8B%E5%A7%8B%E3%81%95%E3%82%8C%E3%81%AA%E3%81%84%E5%89%8D%E3%81%AB%E5%91%BC%E3%81%B3%E5%87%BA%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoListParagraph%22%20style%3D%22margin-left%3A%201.5in%3B%20text-indent%3A%20-.25in%3B%20mso-list%3A%20l0%20level3%20lfo1%3B%22%3E%3CSPAN%20style%3D%22mso-bidi-font-family%3A%20Wingdings%3B%20mso-list%3A%20Ignore%3B%20mso-ansi-language%3A%20IT%3B%20font-family%3A%20Wingdings%3B%20mso-fareast-font-family%3A%20Wingdings%3B%22%3E%C2%A7%3CSPAN%20style%3D%22font%3A%207.0pt%20'Times%20New%20Roman'%3B%22%3E%26nbsp%3B%20%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20lang%3D%22IT%22%20style%3D%22mso-ansi-language%3A%20IT%3B%22%3E%E3%82%B9%E3%82%BF%E3%83%BC%E3%83%88%E3%82%A2%E3%83%83%E3%83%97%E3%81%AE%202%20%E7%95%AA%E7%9B%AE%E3%81%AE%E9%83%A8%E5%88%86%E3%81%AF%E3%80%81I%2FO%20%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%E3%81%BE%E3%81%9F%E3%81%AF%E3%82%B9%E3%82%BF%E3%83%83%E3%82%AF%E3%81%AE%E5%88%9D%E6%9C%9F%E5%8C%96%E3%81%AB%E5%AF%BE%E3%81%97%E3%81%A6%20_bsp_init()%20%E9%96%A2%E6%95%B0%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%97%E3%80%81%E5%88%9D%E6%9C%9F%E5%8C%96%E5%BE%8C%E3%81%AE%E6%93%8D%E4%BD%9C%E3%81%AB%E5%AF%BE%E3%81%97%E3%81%A6%20_bsp_post_init()%20%E9%96%A2%E6%95%B0%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%99%E3%82%8B%E5%88%A5%E3%81%AE_mqx_init_task%E3%81%A7%E8%A1%8C%E3%82%8F%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82_bsp_post_init()%20%E9%96%A2%E6%95%B0%E3%81%AE%E5%AE%9F%E8%A1%8C%E5%BE%8C%E3%80%81_mqx_init_task%E3%81%AF%E7%A0%B4%E6%A3%84%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoListParagraph%22%20style%3D%22margin-left%3A%201.0in%3B%20text-indent%3A%20-.25in%3B%20mso-list%3A%20l0%20level2%20lfo1%3B%22%3E%3CSPAN%20style%3D%22mso-list%3A%20Ignore%3B%20mso-ansi-language%3A%20IT%3B%20font-family%3A%20'Courier%20New'%3B%20mso-fareast-font-family%3A%20'Courier%20New'%3B%22%3Eo%3CSPAN%20style%3D%22font%3A%207.0pt%20'Times%20New%20Roman'%3B%22%3E%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20lang%3D%22IT%22%20style%3D%22mso-ansi-language%3A%20IT%3B%22%3E%E7%8F%BE%E5%9C%A8%E3%80%81%E3%81%99%E3%81%B9%E3%81%A6%E3%81%AE%20BSP%20%E3%81%8C%E3%81%93%E3%81%AE%E6%A6%82%E5%BF%B5%E3%81%AB%E5%90%88%E3%82%8F%E3%81%9B%E3%81%A6%E8%AA%BF%E6%95%B4%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E3%81%99%E3%81%B9%E3%81%A6%E3%81%AE%E5%85%A5%E5%87%BA%E5%8A%9B%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%E3%81%AF%E3%80%81MQX%20%E3%82%B9%E3%82%B1%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%A9%E3%83%BC%E3%81%AE%E9%96%8B%E5%A7%8B%E5%BE%8C%E3%81%AB_mqx_init_task%E3%81%AE%E3%82%B3%E3%83%B3%E3%83%86%E3%82%AD%E3%82%B9%E3%83%88%E3%81%A7%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%E3%81%93%E3%81%AE%E6%A6%82%E5%BF%B5%E3%81%A7%E3%81%AF%E3%80%81%E8%A4%87%E9%9B%91%E3%81%AA%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%E3%81%AE%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%E3%82%82%E5%8F%AF%E8%83%BD%E3%81%AB%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%99%20(%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%E3%81%AE%E5%88%9D%E6%9C%9F%E5%8C%96%E4%B8%AD%E3%81%AB%20ISR%20%E3%82%92%E5%87%A6%E7%90%86%E3%81%97%E3%80%81%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%E3%81%AF%20_time_delay%20%E3%81%AA%E3%81%A9%E3%81%AE%E3%83%96%E3%83%AD%E3%83%83%E3%82%AF%E6%A9%9F%E8%83%BD%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99)%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoListParagraph%22%20style%3D%22margin-left%3A%201.0in%3B%22%3E%3CSPAN%20lang%3D%22IT%22%20style%3D%22mso-ansi-language%3A%20IT%3B%22%3E%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoListParagraph%22%20style%3D%22text-indent%3A%20-.25in%3B%20mso-list%3A%20l0%20level1%20lfo2%3B%22%3E%3CSPAN%20style%3D%22mso-bidi-font-family%3A%20Symbol%3B%20mso-bidi-font-weight%3A%20bold%3B%20mso-list%3A%20Ignore%3B%20font-family%3A%20Symbol%3B%20mso-fareast-font-family%3A%20Symbol%3B%22%3E%E3%83%BB%3CSPAN%20style%3D%22font%3A%207.0pt%20'Times%20New%20Roman'%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSTRONG%3E%E6%97%A2%E7%9F%A5%E3%81%AE%E5%95%8F%E9%A1%8C%3C%2FSTRONG%3E%3C%2FP%3E%3CP%20class%3D%22MsoListParagraph%22%20style%3D%22margin-left%3A%201.0in%3B%20text-indent%3A%20-.25in%3B%20mso-list%3A%20l0%20level2%20lfo2%3B%22%3E%3CSPAN%20style%3D%22mso-list%3A%20Ignore%3B%20font-family%3A%20'Courier%20New'%3B%20mso-fareast-font-family%3A%20'Courier%20New'%3B%22%3Eo%3CSPAN%20style%3D%22font%3A%207.0pt%20'Times%20New%20Roman'%3B%22%3E%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3C%2FSPAN%3E%E6%97%A2%E7%9F%A5%E3%81%AE%E5%95%8F%E9%A1%8C%E3%81%A8%E5%88%B6%E9%99%90%E4%BA%8B%E9%A0%85%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E3%81%AF%E3%80%81%E3%83%AA%E3%83%AA%E3%83%BC%E3%82%B9%E3%83%8E%E3%83%BC%E3%83%88%E3%82%92%E5%8F%82%E7%85%A7%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3CSPAN%20style%3D%22mso-ascii-font-family%3A%20Calibri%3B%20mso-ascii-theme-font%3A%20minor-latin%3B%20mso-hansi-font-family%3A%20Calibri%3B%20mso-hansi-theme-font%3A%20minor-latin%3B%20mso-bidi-font-family%3A%20'Times%20New%20Roman'%3B%20mso-bidi-theme-font%3A%20minor-bidi%3B%22%3E%20%3C%2FSPAN%3E%3C%2FP%3E%3C%2FDIV%3E%3C%2FLINGO-BODY%3E
評価なし
バージョン履歴
最終更新日:
‎02-28-2014 03:22 PM
更新者:
