variable modified in SPC5748G
longfeiwang
If I modify a variable in the Z2(SPC5748G)  CPU core, can I notify Z4_0, Z4_1 by the way of  interruptter I have modified this variable?If this method is ok, can it be used in any core?
petervlna
Sure, this can be done by your SW.
Once you finish modification, just call SW interrupt for other 2 cores.
If you doing modifications in interrupt, you can set interrupt to all 3 cores.
I wonder what is the purpose of this?
regards,
Peter
longfeiwang
Thanks it's useful
