questions about etpu programming
1,311 次查看
leeeea
Hi NXP team,
I am curious about etpu programming, not using the already compiled nxp projects.
So I downloaded CodeWarrior for eTPU 10.3 and opened AN4907SW and opened eTPU_Dev_CodeWarrior10.2.2 folder.
I first thought that microcodes and global variables should be generated after building the project, but I don't think they are created after building the project.
How can I generate etpu_set.h source code(Image of the compiled eTPU code binary)?
Do I have to download different compiler for etpu?
Since I don't have much time right now, I couldn't buy the book you recommended on other similar questions (I am currently living in South Korea and shipping time takes so long)
1,291 次查看
johndiener
Another learning option to try would be a demo of the ASH WARE eTPU tools, see https://www.ashware.com/demos.  Free and comes with quite a few demos, including one for AN4907.  Note that the ASH WARE eTPU compiler produces the tightest executable code of any of the available tools, which is occasionally important.
John Diener
