mpc5848G-Flexcan driver Tx/RX
SKC123
I am using Flexcan driver for MPC5748G. I want to Tx and RX the different CANID. In demo project are provided the hardcoded (TX_MsgID)  CANID there is any way to provide the different CANID. Guide me
Thanks regards,
SKC123
PetrS
which driver do you mean, SDK driver? If yes then for RX operation using FLEXCAN_DRV_ConfigRxMb you prepare MB for reception of given ID and with FLEXCAN_DRV_Receive you start reception into this MB. For sending message you can simply use FLEXCAN_DRV_Send with defined ID to be send.
BR, Petr
SKC123
Thanks, there is sample code. can u please share it
Thanks and regard
SKC123
PetrS
Within S32 DEsign Studio you can find either non-SDK or SDK projects
BR, Petr
