mpc5777c
mpc5777c
2,030件の閲覧回数
PENGHAN
 I would like to consult how to find documentation on the assembly instruction set of the mpc5777c chip,
such as stw,wrteei.
Regrads
2,022件の閲覧回数
davidtosenovjan
These are two different instruction sets. See attached presentation slide:
BookE comprises 32-bit instructions only:
http://www.nxp.com/files/32bit/doc/ref_manual/EREF_RM.pdf
VLE comprises 16-bit and 32-bit instructions:
http://www.nxp.com/files/32bit/doc/ref_manual/VLEPEM.pdf
It is needed to choose such one that is used in you project. Usually VLE is now much common one and usually default configuration.
