mpc5744p bootloader
mpc5744p bootloader
yanzc
Can you provide the mpc57440 bootlader for me ? I can't find it.
宝程凡
How did you end up solving it?Can you share with me?Thank you!
petervlna
Ekaitz
The links of your post are not available. Can I found this informatiom in an other site?
Ekaitz
yuanqingdong
Fresh Out Contributor
HI , peter ,  thank for you support , i am try to write the bootloader of mpc5744 ,I'm very lucky to see the demo what you give .but the demo  you give   is  mpc5748G, the IDE you use is Green Hills MULTI IDE ,  My IDE is  S32 Design Studio for Power Architecture , What should I pay attention to during the transplant?   thank you.
petervlna
The main difference will be in correct linker file. Rest of the code can be simply copied.
Peter
