mpc5
mpc5
2,379件の閲覧回数
Hossein_mhp1993
I wanted to run 5 motors with a microcontroller. I wanted to know which series of microcontrollers should be used that have more etimer and pwm?
2 返答(返信)
2,365件の閲覧回数
PetrS
depends what kind of motors you are using and what kind of control technique is used. There will be no issue to drive e.g. 1phase DC motors with available set of FlexPWM and eTimer modules. Driving 3phase motors require more resources.
MPC5744P has 2 FlexPWM modules with 4 x (2+1) channels and 3 eTimer modules with 6 channels
BR, Petr
2,334件の閲覧回数
Hossein_mhp1993
Thank you for your guidance.
We have 5 BLDC motors and need at least 15 PWM channels. We also use ETIMER for the CAPTURE of the Hall sensor of these 5 engines. thanks for your help  in advance.
タグ(1)
