microsecond channel driver development
2,401件の閲覧回数
wrathofhelix
Hello ,
I am working on developmet of MSC bus driver, but there is no reference/application note for feature CSI/TSB as downstream channel. Is there any application note/reference to implement feature CSI/TSB mode for MSC?
Thanks/Regards
3 返答(返信)
2,380件の閲覧回数
davidtosenovjan
2,376件の閲覧回数
wrathofhelix
Hello @davidtosenovjan ,
I read all related topics on community page, but I meant that I need Microsecond Channel configuration to configure DSPI. For example , common settings, frame size, chip select etc. Comments are not enough which you mentioned.  Don't you have any application note to implement this configuraton as an example?
Thnaks/Regards
2,335件の閲覧回数
davidtosenovjan
I think we don't have such example. „Microsecond channel“ is third-party protocol and I communication parameters should be defined by slave device. However it should be achievable by TSB extension to the DSPI module.
