intrinsic_function
intrinsic_function
2,912件の閲覧回数
Jamber_H
Hi, what's intrinsic_function meaning in flow code?
extern void __mtdcr( const unsigned int,  int) __attribute__((intrinsic_function(2090, 0, "mtdcr") ));
extern void __mtspr( const unsigned int,  int) __attribute__((intrinsic_function(2090, 4, "mtspr") ));
extern int __mfspr( const unsigned int) __attribute__((intrinsic_function(2016, 4, "mfspr") ));
Jamber
5 返答(返信)
2,905件の閲覧回数
davidtosenovjan
Hi, where this definitions are taken from?
2,893件の閲覧回数
Jamber_H
Hi, David
It's source code of an OS used for MPC5744
Best Regsrds
Jamber
2,882件の閲覧回数
davidtosenovjan
OK, but it is not a syntax use with S32 Design Studio or some of its component? Or is it?
2,873件の閲覧回数
Jamber_H
The compiler is WindRiver, and IDE is S32DS.
2,858件の閲覧回数
davidtosenovjan
I would apparently forward you to WindRiver support
https://www.windriver.com/support/index.html
because this question is specifically related to directives' syntax of Diab compiler.
