how to migrate the bootloader from MPC5634M TO MPC5643L
steven_zhang
Contributor V
lukaszadrapa
Hi @steven_zhang
there are some differences, so it won't be so straightforward. For example, there's Mode Entry module on MPC5643L but not on MPC5634M, the layout of flash blocks is little bit different... You should create new project directly for MPC5643L because the startup files are different - it's necessary to initialize core registers due to lock step etc...
Lukas
steven_zhang
Contributor V
do you have the bootloader project for SPC5643L?  how can i get it?
lukaszadrapa
No, we do not have bootloader written directly for MPC5643L. I have only draft of application note for MPC5634M (attached). I'm not sure - do you refer to this one or do you have own bootloader for MPC5634M?
If you are looking for production code, here's an option:
https://www.vector.com/int/en/products/products-a-z/embedded-components/flash-bootloader/
Lukas
