how to configure Processor Expert
ソリューションへジャンプ
3,162件の閲覧回数
FAISAL0323
I am facing difficulty in enabling pretended networking in processor expert configuration.(initially it is disabled as shown in picture). Please someone let me know how to enable it through Processor Expert?
would be thankful
3,151件の閲覧回数
PetrS
pretended networking is only available on FlexCAN_0, for other modules is unavailable so cannot be set in component.
BR, Petr
4 返答(返信)
3,152件の閲覧回数
PetrS
BR, Petr
3,138件の閲覧回数
FAISAL0323
Hi. I have tried that but there is another issue. Since pretended networking is only available for flexcan 0 as you mentioned above  but when I select that flexcan 0 and give range for can ID filtering, processor expert is unable to generate code as it says that peripheral is already been used. how to overcome that issue?
what I want to do is to set Mask for filtering  CAN IDs from 0x580 TO 0x5FF to keep ECU wake up.
please let me know if there is any solution. Thanks
3,105件の閲覧回数
PetrS
seems you have already one component assigned to CAN0 in your project. You cannot have two components using same module. Error message is quite clear here.
BR, Petr
3,144件の閲覧回数
FAISAL0323
I got it, Thanks for your reply. much appreciated
