eTPU spark supression
1,156 次查看
barbiani
I have once seen an eTPU documentation paragraph about suppressing the spark after a long dwell event but now that I need it I can not find anymore.
Can someone point me to the eTPU function/pdf that explains the procedure?
Thank you.
1 回复
1,090 次查看
davidtosenovjan
Hi, I believe you mean this:
Referenced document:
https://www.nxp.com/docs/en/application-note/AN4907.pdf
Hope it helps
