destructive reset
destructive reset
2,127 次查看
abdelrhman
At each destructive reset, a reset sequence is initiated causing the SW application to restart and the RGM_DRET register will be written again with the threshold escalation number causing the the reset escalation counter to reset
My question, How the reset escalation counter can reach the threshold number of destructive reset ??
2,115 次查看
petervlna
Only only reason I see is the program will not reach reset escalation threshold update and it resets before. (so no update is performed)
Simply place write breakpoint on your DRET in debugger to see if it is updated by SW or not.
Check your reset sources.
Peter
