bootloader jump to App
pyi285
Is there a way to go from the bootloader to the application? I posted it the other day, but I couldn't solve it properly, so is there someone who can explain the detailed code or how to do it? Is there anyone who can explain in detail because I didn't understand the datasheet related to the bootloader (MPC5674M chip) last time?
PS :
__asm__("e_lis %r12,0x000100");
__asm__("e_or2i %r12,0x000100 "); //JUMP_ADDRESS
__asm__("mtlr r0");
__asm__("se_blrl");
can i do it with the code above
The internal flash address that stores the current APP starts at 0x00010000 and ends at 0x00013100.
#MPC5674F #Jump # Application #Bootloader
davidtosenovjan
Hi, what you show cannot work because you are loading address to register r12, but to link register you are loading content of r0.
davidtosenovjan
