application code start address
abdelrhman
in MPC5744P, cpu0_reset_vec, in the linker file, points to the application start address, doesn't it ?
petervlna
It points to the address where the code execution will start after valid RCHW is found at address 0x00FA0000.
In this care the application will start at address defined at 0x00FA0004.
Peter
abdelrhman
Yes, I'm referring to the linker_flash.Id linker file of example application projects
petervlna
well, this depends on what you have in linker. You can define any kind of label for it.
Are you referring to any specific linker file?
Simply have a look at cpu0_reset_vec section definition and you will see where starts and ends.
Peter
