Dear Mr./Mrs.
I am trying to reset my MPC5777C MCU by using FCCU, when fault is happened by SWT. When I have initialized SWT, it resets my CPU only one time without second or more resets. However, I want STW to reset my CPU continuously whenever time-out occurs. I use FCCU for resetting my MCU.
Which problem does it lead to this situation? I look forward to your reply?
Best regards.
Solved! Go to Solution.
Do you clear FCCU faults after startup? What you code does after SWT timeout reset? Could you provide details of your configuration?
Dear David,
Thank you for replying my question. I cleared FCCU faults after startup so problem was solved.
Best Regards.
Talk is cheap, show me code. (L.T)
