VPP_TEST FCCU Configuration
ahmedsoubky
Greetings,
I was wondering how to configure the FCCU to monitor the VPP_TEST pin to ensure that it is kept low ?
Thanks in advance,
Ahmed Soubky
petervlna
Yes, these faults are there exactly for this purpose.
Furthermore they monitor also unintended TEST mode entry due to other various reasons like MC_ME failure.
I recommend you to configure reset reaction on all TCU faults (40 -43) as TEST mode should be used only during factory testing.
Peter
ahmedsoubky
Hi Peter,
Thanks for the answer.
We are using MPC5744p micro.
Furthermore, there is a requirement to configure the FCCU to monitor the VPP_TEST pin to ensure it is kept low.
Is it enough to configure a reset reaction to the faults 40,41,42, and 43 in the FCCU ?
Kind Regards,
Ahmed
petervlna
Peter
ahmedsoubky
Thank you very much!
petervlna
FCCU can't monitor VPP_TEST pin. FCCU can monitor only faults described in FCCU chapter as NCFs.
But you didn't even specify your micro, so...
Just tie it to the ground.
Peter
petervlna
Now I realized that there is no need to monitor this pin as FCCU monitor unexpected activation of TEST mode.
You can find more details here:
http://www.nxp.com/assets/documents/data/en/application-notes/AN5259.pdf?&fsrch=1&sr=1&pageNum=1
Peter
