UART Tx Observation
UART Tx Observation
archansathe
Hello, I am using MPC5604B. I am continuously transmitting UART frames in polling mode (LINFlex_4) and receiving frame using interrupt mode. Randomly at some time, Tx stops. DTF flag is not set. I can see the data to be sent in BDRL register but it does n
martin_kovar
please send the code with UART initialization and data sending.
Martin
archansathe
Hello Thanks for reply.
When I dig more in the code, I found Tx is getting stopped because I am getting a software reset. But before reset  I observe lot of unexpected (Data Storage) interrupts are coming. What could be the reasons for these interrupts? When this interrupt occurs?
martin_kovar
Which bits in LINIER register you have set? Which interrupt flag is set?
Martin
