Two keyslot setting
Two keyslot setting
qingsong_wu
If it's possible to configurate two flexray key slot in MPC5748G/C?
To make sure an ECU with MPC5748G/C is able to wakeup a TT-L cluster(only two flexray node in the cluster, another node is a non-sync node) ,  pSecondKeySlotID and pTwoKeySlotMode should be supported by MPC5748G/C.
juunna
hello, i want to know how to set two coldstart node ,i set tow MC9S12XF512node which was setted two keyslot to wakeup MFR4310node which was setted follow and  no keyslot , the other information is the same ,All is support FlexRay 2.1,but why they cannt communication ?
lukaszadrapa
I'm not FlexRay expert but the module on MPC5748G is designed according to FlexRay 2.1 Protocol Specification. This one talks only about pKeySlotId.
pSecondKeySlotID is specified in FlexRay 3.0.1 Protocol Specification.
So, the answer should be that this is not supported by MPC5748G.
Hope this helps.
Lukas
juunna
hello, i want to know how to set two coldstart node ,i set two MC9S12XF512 node which was setted two keyslot to wakeup MFR4310 node which was setted follow and  no keyslot , the other information is the same ,All is support FlexRay 2.1,but why they cannt communication ?
qingsong_wu
Hi Lukas,
Thank you for your reply.
MPC5748G can be repalced in our project. But the new chip should be very similar to MPC5748.
Is there any other alternative chip that support FlexRay 3.0.1 ?
lukaszadrapa
Only FlexRay 2.1 is available on current MPC5xxx and S32 devices.
Lukas
juunna
juunna
hello, i want to know how to set tow coldstart node ,i set tow MC9S12XF512node which was setted two keyslot to wakeup MFR4310node which was setted follow and  no keyslot , the other information is the same ,All is support FlexRay 2.1,but why they cannt communication ?
