TJA1100 remote loopback
已解决
跳至解决方案
2,190 次查看
chaoy
HI
   My configuration is as follow.
   Basic control register (Register 0) :0x6120
   Extended control register (Register 17) :0x981a
   i read the register after i write it.i looks right
how to test? ping phy on PC?
1 解答
2,136 次查看
Bulat
Remote loopback test assumes that the remote partner sends data to the PHY via ethernet line, and the PHY returns these data back to the remote parter. In your case the PC should receive the same ethernet frames that it sends to the line.
Bulat
在原帖中查看解决方案
1 回复
2,137 次查看
Bulat
Bulat
