SDK,IC
SDK,IC
2,387 次查看
zhang_ke_dong
When I was using the MPC5744P chip,When using the IC module of the SDK,After I configure to collect high levels,I call the SDK to switch to the collection cycle,After cyclic collection, it is found that the collected high level data is always wrong, while the cycle is right. Why is this.
1 回复
2,377 次查看
PetrS
where do you call those functions? In callback function? Can you share whole project you have?
What if you call IC_StopChannel before and IC_StartChannel after you change mode?
BR, Petr
