Register Protection for MPC5746C
3,979 次查看
mayank22
These are the Modules on which I am implementing Locking mechanism under Register Protection for MPC5746C.
    0xFFFB0140, /* CMU------------*/
    0xFFFB0040, /* FXOSC----------*/
    0xFFFB0180, /* MC_CGM --------*/
    0xFFFB8000, /* MC_ME ---------*/
    0xFFFA8000, /* MC_RGM --------*/
    0xFFF50000, /* MEMU_0 -------*/
    0xFFFB0080, /* PLLDIG --------*/
    0xFFFA0400, /* PMCDIG --------*/
    0xFFFC0000, /* SIUL2 ---------*/
    0xFFFB0100, /* SXOSC ---------*/
    0xFFF9C000 /* LPU_CTL -------*/
    1. Sample 1: (0xFFFB0000, offset - 0x4, 32-bit protection)
Register: Matches ME_MCTL (mode control register, 32-bit protection, offset 0x4 per Table 77-5).
Base Address: 0xFFFB0000.
Protection Size: 32 bits (all four bytes are protected).
Calculations
Normal Address: base + offset = 0xFFFB0000 + 0x4 = 0xFFFB0004
Mirrored Address (Area 3): base + 0x2000 + offset = 0xFFFB0000 + 0x2000 + 0x4 = 0xFFFB2004
Soft Lock Bits Address (Area 4):
Offset in Area 4: offset/4 = 0x4 / 4 = 0x1.
Address: base + 0x3800 + offset/4 = 0xFFFB0000 + 0x3800 + 0x1 = 0xFFFB3801.
For a 32-bit register, all four SLBs (SLB0–SLB3) control the four bytes (e.g., 0x4 to 0x7).
Soft Locking
Option 1: Write to Mirrored Address:
Write a 32-bit value to 0xFFFB2004 (e.g., 0x80000000 to initiate a mode transition; refer to MC_ME chapter for valid values).
This updates ME_MCTL at 0xFFFB0004 and sets SLB0–SLB3 in the SLBRn register at 0xFFFB3801.
Example: *(volatile uint32_t *)0xFFFB2004 = 0x80000000;
Option 2: Direct SLB Write:
Write to 0xFFFB3801 to set SLB0–SLB3.
Write 0xFF (WE0–WE3=1, SLB0–SLB3=1) to lock all four bytes.
Example: *(volatile uint8_t *)0xFFFB3801 = 0xFF;
Unlocking
Write 0xF0 to 0xFFFB3801 (WE0–WE3=1, SLB0–SLB3=0) to clear SLB0–SLB3, unlocking the register.
Example: *(volatile uint8_t *)0xFFFB3801 = 0xF0;
Hard Locking
Write 0x00000001 to 0xFFFB3FFC to set GCR.HLB, locking SLBs until reset.
Example: *(volatile uint32_t *)0xFFFB3FFC = 0x00000001;
Below in an example of register set whose all 4 address set are enable and can be R/W.
Below in an example of register set whose Base + offset & Mirror addresses are enabled and can be R/W and other addresses can’t be set.
This poses a serious issue as SLB bits confirms soft locking and GCR bits are set to implement hard lock.
For All MC_CGM caped registers I can find the same problem.
What could be the reason for these different behavior. Some addresses can be modified and changed other are reserved.
8 回复数
3,447 次查看
mayank22
Hi Peter ,
Thank you for the help. I can configure Soft lock and monitor SLB for all modules now.
I have another question regarding Hard Lock GCR bit. According to your explanation for all the MCCGM capped modules which are  CMU,FXOSC,SXOSC, PLLDIG and MCCGM shall have one common base address , that is 0xFFFB0000.
now according to section 77.1.1 Register protection configuration, the NOTE talks about operations in Low power mode.
As I said , having the same base address , if I Hard lock any one module , all other modules are getting hard locked automatically, which raises issue in Low power mode. since I do not want FXOSC/SXOSC and CMU to be hard locked here.
is there any way around this problem.
Thanks and regards
3,416 次查看
petervlna
The register protection is applied Pbridge.
And on the PBRIDGE is the MC_CGM module:
Which have then mapped peripherals under MC_CGM. Looks like you will need to use SLB instead of HLB to solve this.
As HLB will lock whole MC_CGM.
Peter
3,886 次查看
petervlna
I have checked the PREG_PROT and it behave like described in reference manual:
on ME_CGM register SC_DC0:
Base :  0xFFFB0000 + Offset 7E8
Mirror: 0xFFFB07E8
= Base (0xFFFB0000) + Offset(7E8) + Mirror (0x2000)
In the example I have locked the SC_DC0 form ME_CGM module by Soft lock.
Here is the breakdown:
Area 4:  is 1.5 KB and holds the Soft Lock Bits, one bit per byte in area 1. The four Soft Lock Bits associated with one module register  word are arranged at byte boundaries in the memory map. The Soft Lock Bit registers can be directly written using a bit mask.
So you have to divide the area of Soft lock bits by 8 to see corresponding SLB settings.
Base (of module) + 3800 + (one bit per byte of area 1)
For Hard lock bit it is one for whole module.
Area 5 is 512 bytes large and holds the configuration bits of the protection mode. There is one configuration hard lock bit per module that prevents all further modifications to the Soft Lock Bits and can only be cleared by a system reset once set. The other bits, if set, will allow user access to the protected module.
Base (of module) 0xFFFB0000 + Offset 3FFC
As GCR is at end of area 5.
Peter
3,697 次查看
mayank22
Hi Peter , here are some samples where SLB and GCR are not working.  can You please check this addresses and confirm if they show different behavior. if not then what could be the problem with these modules ?
1. MC_CMU -  0xFFFB0140 -  { MODULE_CMU, 0xC,REG_SIZE_16}, CMU_LFREFR
    1. Base Address - 0xFFFB014C
    2. Mirror Address -0xFFFB214C
    3. SLB -0xFFFB3943
    4. GCR - 0xFFFB413C
2. MC_CMU -  0xFFFB0140   { MODULE_CMU, 0x18,REG_SIZE_32}, CMU_MDR
    1. Base Address - 0xFFFB0158
    2. Mirror Address - 0xFFFB2158
    3. SLB - 0xFFFB3946
    4. GCR - 0xFFFB413C
3. PLLDIG 0xFFFB0080 - { MODULE_PLLDIG, 0x20, REG_SIZE_16}, PLLDIG_PLLCR
    1. Base Address - 0xFFFB00A0
    2. Mirror Address - 0xFFFB20A0
    3. SLB - 0xFFFB0F5D
    4. GCR - 0xFFFB407C
4. PLLDIG 0xFFFB0080 - { MODULE_PLLDIG, 0x28,REG_SIZE_32}, PLLDIG_PLLDV
    1. Base Address - 0xFFFB00A8
    2. Mirror Address - 0xFFFB20A8
    3. SLB - 0xFFFB388A
    4. GCR - 0xFFFB407C
5. PMCDIG 0xFFFA0400 - { MODULE_PMCDIG, 0x0,REG_SIZE_32},
  1. Base Address - 0xFFFA0400
  2. Mirror Address - 0xFFFA2400
  3. SLB - 0xFFFA3C00
  4. GCR - 0xFFFA43FC
6. PMCDIG 0xFFFA0400 -{ MODULE_PMCDIG, 0x10,REG_SIZE_32},
    1. Base Address - 0xFFFA0410
    2. Mirror Address - 0xFFFA2410
    3. SLB - 0xFFFA3C04
    4. GCR - 0xFFFA43FC
3,674 次查看
petervlna
Looking at simple test: MC_CMU - CSR
Base Address - 0xFFFB014C - This is offset address. Not Base.
Base for MC_CMU module is 0xFFFB 0140.
Would be base +offset + mirror
SLB -0xFFFB3943
Take as base address of whole CGM as present in ref manual:
So calculations are:
0xFFFB0000 + 3800 + position of SLB
GCR - 0xFFFB413C
Same as above
0xFFFB0000+3FF0
Peter
3,588 次查看
mayank22
Hi , This is also not working .
CMU_LFREFR 32
Offset 0xCh
Protected size - 16 (Bytes 2 and 3)
0xFFFB0000, /* CMU----------*/
Base address -0xFFFB000C
Mirror address -0xFFFB200C
SLB - 0xFFFB3803
GCR - 0xFFFB3FFC
3,583 次查看
petervlna
Here is the result of SLB for
CMU_LFREFR 32 -  addresses base and offset
Base for CGM module is  0xFFFB_0000
CMU offset is 0x140
CGM LFREFR offset is 0x14C from module base
I set SLB for CMU_LFREFR via write to mirror
Peter
3,958 次查看
petervlna
I will test it and come back to you ASAP.
Peter
%3CLINGO-SUB%20id%3D%22lingo-sub-2135716%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EMPC5746C%20%E7%9A%84%E5%AF%84%E5%AD%98%E5%99%A8%E4%BF%9D%E6%8A%A4%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2135716%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E8%BF%99%E4%BA%9B%E6%98%AF%E6%88%91%E4%B8%BA%20MPC5746C%20%E5%AE%9E%E7%8E%B0%E5%AF%84%E5%AD%98%E5%99%A8%E4%BF%9D%E6%8A%A4%E4%B8%8B%E9%94%81%E5%AE%9A%E6%9C%BA%E5%88%B6%E7%9A%84%E6%A8%A1%E5%9D%97%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%20%20%20%200xFFFB0140%2C%20%2F*%20CMU------------*%2F%3C%2FP%3E%3CP%3E%20%20%20%200xFFFB0040%2C%20%2F*%20FXOSC----------*%2F%3C%2FP%3E%3CP%3E%20%20%20%200xFFFB0180%2C%20%2F*%20MC_CGM%20--------*%2F%3C%2FP%3E%3CP%3E%20%20%20%200xFFFB8000%2C%20%2F*%20MC_ME%20---------*%2F%3C%2FP%3E%3CP%3E%20%20%20%200xFFFA8000%2C%20%2F*%20MC_RGM%20--------*%2F%3C%2FP%3E%3CP%3E%20%20%20%200xFFF50000%2C%20%2F*%20MEMU_0%20-------*%2F%3C%2FP%3E%3CP%3E%20%20%20%200xFFFB0080%2C%20%2F*%20PLLDIG%20--------*%2F%3C%2FP%3E%3CP%3E%20%20%20%200xFFFA0400%2C%20%2F*%20PMCDIG%20--------*%2F%3C%2FP%3E%3CP%3E%20%20%20%200xFFFC0000%2C%20%2F*%20SIUL2%20---------*%2F%3C%2FP%3E%3CP%3E%20%20%20%200xFFFB0100%2C%20%2F*%20SXOSC%20---------*%2F%3C%2FP%3E%3CP%3E%20%20%20%200xFFF9C000%20%2F*%20LPU_CTL%20-------*%2F%3C%2FP%3E%3COL%3E%3COL%3E%3CLI%3E%3CSTRONG%3E%E6%A0%B7%E6%9C%AC%201%EF%BC%9A%EF%BC%880xFFFB0000%EF%BC%8C%E5%81%8F%E7%A7%BB%20-%200x4%EF%BC%8C32%20%E4%BD%8D%E4%BF%9D%E6%8A%A4%EF%BC%89%3C%2FSTRONG%3E%3C%2FLI%3E%3C%2FOL%3E%3C%2FOL%3E%3CP%3E%3CSTRONG%3E%E5%AF%84%E5%AD%98%E5%99%A8%3C%2FSTRONG%3E%EF%BC%9A%E4%B8%8E%20ME_MCTL%EF%BC%88%E6%A8%A1%E5%BC%8F%E6%8E%A7%E5%88%B6%E5%AF%84%E5%AD%98%E5%99%A8%EF%BC%8C32%20%E4%BD%8D%E4%BF%9D%E6%8A%A4%EF%BC%8C%E5%81%8F%E7%A7%BB%200x4%EF%BC%8C%E8%A7%81%E8%A1%A8%2077-5%EF%BC%89%E5%8C%B9%E9%85%8D%E3%80%82%3C%2FP%3E%3CP%3E%3CSTRONG%3E%E5%9F%BA%E5%9C%B0%E5%9D%80%3C%2FSTRONG%3E%EF%BC%9A0xFFFB0000%E3%80%82%3C%2FP%3E%3CP%3E%3CSTRONG%3E%E4%BF%9D%E6%8A%A4%E5%A4%A7%E5%B0%8F%3C%2FSTRONG%3E%EF%BC%9A32%20%E4%BD%8D%EF%BC%88%E6%89%80%E6%9C%89%E5%9B%9B%E4%B8%AA%E5%AD%97%E8%8A%82%E5%9D%87%E5%8F%97%E4%BF%9D%E6%8A%A4%EF%BC%89%E3%80%82%3C%2FP%3E%3CP%3E%3CSTRONG%3E%E8%AE%A1%E7%AE%97%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E%E6%AD%A3%E5%B8%B8%E5%9C%B0%E5%9D%80%3C%2FSTRONG%3E%EF%BC%9A%E5%9F%BA%E6%95%B0%20%2B%20%E5%81%8F%E7%A7%BB%E9%87%8F%20%3D%200xFFFB0000%20%2B%200x4%20%3D%200xFFFB0004%3C%2FP%3E%3CP%3E%3CSTRONG%3E%E9%95%9C%E5%83%8F%E5%9C%B0%E5%9D%80%EF%BC%88%E5%8C%BA%E5%9F%9F%203%EF%BC%89%3C%2FSTRONG%3E%EF%BC%9A%E5%9F%BA%E6%95%B0%20%2B%200x2000%20%2B%20%E5%81%8F%E7%A7%BB%20%3D%200xFFFB0000%20%2B%200x2000%20%2B%200x4%20%3D%200xFFFB2004%3C%2FP%3E%3CP%3E%3CSTRONG%3E%E8%BD%AF%E9%94%81%E5%AE%9A%E4%BD%8D%E5%9C%B0%E5%9D%80%EF%BC%88%E5%8C%BA%E5%9F%9F%204%EF%BC%89%3C%2FSTRONG%3E%EF%BC%9A%3C%2FP%3E%3CP%3E%E5%8C%BA%E5%9F%9F%204%20%E4%B8%AD%E7%9A%84%E5%81%8F%E7%A7%BB%E9%87%8F%EF%BC%9Aoffset%2F4%20%3D%200x4%20%2F%204%20%3D%200x1%E3%80%82%3C%2FP%3E%3CP%3E%E5%9C%B0%E5%9D%80%EF%BC%9A%20base%20%2B%200x3800%20%2B%20offset%2F4%20%3D%200xFFFB0000%20%2B%200x3800%20%2B%200x1%20%3D%200xFFFB3801%E3%80%82%3C%2FP%3E%3CP%3E%E5%AF%B9%E4%BA%8E%2032%20%E4%BD%8D%E5%AF%84%E5%AD%98%E5%99%A8%EF%BC%8C%E6%89%80%E6%9C%89%E5%9B%9B%E4%B8%AA%20SLB%EF%BC%88SLB0%E2%80%94SLB3%EF%BC%89%E6%8E%A7%E5%88%B6%E5%9B%9B%E4%B8%AA%E5%AD%97%E8%8A%82%EF%BC%88%E4%BE%8B%E5%A6%82%EF%BC%8C0x4%20%E5%88%B0%200x7%EF%BC%89%E3%80%82%3C%2FP%3E%3CP%3E%3CSTRONG%3E%E8%BD%AF%E9%94%81%E5%AE%9A%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E%E9%80%89%E9%A1%B9%201%EF%BC%9A%E5%86%99%E5%85%A5%E9%95%9C%E5%83%8F%E5%9C%B0%E5%9D%80%3C%2FSTRONG%3E%EF%BC%9A%3C%2FP%3E%3CP%3E%E5%90%91%200xFFFB2004%20%E5%86%99%E5%85%A5%2032%20%E4%BD%8D%E5%80%BC%EF%BC%88%E4%BE%8B%E5%A6%82%EF%BC%8C0x80000000%20%E5%8F%AF%E5%90%AF%E5%8A%A8%E6%A8%A1%E5%BC%8F%E8%BD%AC%E6%8D%A2%EF%BC%9B%E6%9C%89%E5%85%B3%E6%9C%89%E6%95%88%E5%80%BC%EF%BC%8C%E8%AF%B7%E5%8F%82%E9%98%85%20MC_ME%20%E7%AB%A0%E8%8A%82%EF%BC%89%E3%80%82%3C%2FP%3E%3CP%3E%E8%BF%99%E5%B0%86%E6%9B%B4%E6%96%B0%200xFFFB0004%20%E7%9A%84%20ME_MCTL%EF%BC%8C%E5%B9%B6%E5%9C%A8%200xFFFB3801%20%E7%9A%84%20SLBRn%20%E5%AF%84%E5%AD%98%E5%99%A8%E4%B8%AD%E8%AE%BE%E7%BD%AE%20SLB0-SLB3%E3%80%82%3C%2FP%3E%3CP%3E%E7%A4%BA%E4%BE%8B*(volatile%20uint32_t%20*)0xFFFB2004%20%3D%200x80000000%EF%BC%9B%3C%2FP%3E%3CP%3E%3CSTRONG%3E%E9%80%89%E9%A1%B9%202%EF%BC%9A%E7%9B%B4%E6%8E%A5%E5%86%99%E5%85%A5%20SLB%3C%2FSTRONG%3E%EF%BC%9A%3C%2FP%3E%3CP%3E%E5%86%99%E5%85%A5%200xFFFB3801%EF%BC%8C%E8%AE%BE%E7%BD%AE%20SLB0-SLB3%E3%80%82%3C%2FP%3E%3CP%3E%E5%86%99%E5%85%A5%200xFF%EF%BC%88WE0%E2%80%94WE3%3D1%EF%BC%8CSLB0%E2%80%94SLB3%3D1%EF%BC%89%E4%BB%A5%E9%94%81%E5%AE%9A%E6%89%80%E6%9C%89%E5%9B%9B%E4%B8%AA%E5%AD%97%E8%8A%82%E3%80%82%3C%2FP%3E%3CP%3E%E7%A4%BA%E4%BE%8B*(volatile%20uint8_t%20*)0xFFFB3801%20%3D%200xFF%EF%BC%9B%3C%2FP%3E%3CP%3E%3CSTRONG%3E%E8%A7%A3%E9%94%81%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%E5%86%99%E5%85%A5%200xF0%20%E8%87%B3%200xFFFB3801%EF%BC%88WE0-WE3%3D1%EF%BC%8CSLB0-SLB3%3D0%EF%BC%89%E4%BB%A5%E6%B8%85%E9%99%A4%20SLB0-SLB3%EF%BC%8C%E8%A7%A3%E9%94%81%E5%AF%84%E5%AD%98%E5%99%A8%E3%80%82%3C%2FP%3E%3CP%3E%E7%A4%BA%E4%BE%8B*(volatile%20uint8_t%20*)0xFFFB3801%20%3D%200xF0%EF%BC%9B%3C%2FP%3E%3CP%3E%3CSTRONG%3E%E7%A1%AC%E9%94%81%E5%AE%9A%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%E5%B0%86%200x00000001%20%E5%86%99%E5%85%A5%200xFFB3FFC%20%E4%BB%A5%E8%AE%BE%E7%BD%AE%20GCR.HLB%EF%BC%8C%E9%94%81%E5%AE%9A%20SLB%20%E7%9B%B4%E5%88%B0%20RESET%E3%80%82%3C%2FP%3E%3CP%3E%E7%A4%BA%E4%BE%8B*(volatile%20uint32_t%20*)0xFFFB3FFC%20%3D%200x00000001%EF%BC%9B%3C%2FP%3E%3CP%3E%E4%B8%8B%E9%9D%A2%E6%98%AF%E4%B8%80%E4%B8%AA%E5%AF%84%E5%AD%98%E5%99%A8%E8%AE%BE%E7%BD%AE%E7%A4%BA%E4%BE%8B%EF%BC%8C%E5%AE%83%E7%9A%84%E6%89%80%E6%9C%89%204%20%E4%B8%AA%E5%9C%B0%E5%9D%80%E8%AE%BE%E7%BD%AE%E9%83%BD%E6%98%AF%E5%90%AF%E7%94%A8%E7%9A%84%EF%BC%8C%E5%8F%AF%E4%BB%A5%E6%98%AF%20R%2FW%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22mayank22_0-1752748012305.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22mayank22_0-1752748012305.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F348051i250A64751649A461%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22mayank22_0-1752748012305.png%22%20alt%3D%22mayank22_0-1752748012305.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E4%B8%8B%E9%9D%A2%E6%98%AF%E4%B8%80%E4%B8%AA%E5%AF%84%E5%AD%98%E5%99%A8%E8%AE%BE%E7%BD%AE%E7%A4%BA%E4%BE%8B%EF%BC%8C%E5%85%B6%E4%B8%AD%E5%9F%BA%E5%9D%80%20%2B%20%E5%81%8F%E7%A7%BB%26amp%3B%20%E9%95%9C%E5%83%8F%E5%9C%B0%E5%9D%80%E5%B7%B2%E5%90%AF%E7%94%A8%EF%BC%8C%E5%8F%AF%E4%BB%A5%E8%AE%BE%E7%BD%AE%E4%B8%BA%20R%2FW%EF%BC%8C%E5%85%B6%E4%BB%96%E5%9C%B0%E5%9D%80%E4%B8%8D%E8%83%BD%E8%AE%BE%E7%BD%AE%E3%80%82%3C%2FP%3E%3CP%3E%E8%BF%99%E5%B8%A6%E6%9D%A5%E4%BA%86%E4%B8%80%E4%B8%AA%E4%B8%A5%E9%87%8D%E7%9A%84%E9%97%AE%E9%A2%98%EF%BC%8C%E5%9B%A0%E4%B8%BA%20SLB%20%E4%BD%8D%E7%A1%AE%E8%AE%A4%E4%BA%86%E8%BD%AF%E9%94%81%E5%AE%9A%EF%BC%8C%E8%80%8C%20GCR%20%E4%BD%8D%E7%9A%84%E8%AE%BE%E7%BD%AE%E5%88%99%E6%98%AF%E4%B8%BA%E4%BA%86%E5%AE%9E%E7%8E%B0%E7%A1%AC%E9%94%81%E5%AE%9A%E3%80%82%3C%2FP%3E%3CP%3E%E5%AF%B9%E4%BA%8E%E6%89%80%E6%9C%89%20MC_CGM%20%E5%B8%A6%E5%B8%BD%E5%AF%84%E5%AD%98%E5%99%A8%EF%BC%8C%E6%88%91%E9%83%BD%E5%8F%91%E7%8E%B0%E4%BA%86%E5%90%8C%E6%A0%B7%E7%9A%84%E9%97%AE%E9%A2%98%E3%80%82%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22mayank22_1-1752748012405.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22mayank22_1-1752748012405.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F348052i8577F080E8066B9B%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22mayank22_1-1752748012405.png%22%20alt%3D%22mayank22_1-1752748012405.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E8%BF%99%E4%BA%9B%E4%B8%8D%E5%90%8C%E8%A1%8C%E4%B8%BA%E7%9A%84%E5%8E%9F%E5%9B%A0%E6%98%AF%E4%BB%80%E4%B9%88%EF%BC%9F%E6%9C%89%E4%BA%9B%E5%9C%B0%E5%9D%80%E5%8F%AF%E4%BB%A5%E4%BF%AE%E6%94%B9%E5%92%8C%E5%8F%98%E6%9B%B4%EF%BC%8C%E6%9C%89%E4%BA%9B%E5%88%99%E8%A2%AB%E4%BF%9D%E7%95%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2148959%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Register%20Protection%20for%20MPC5746C%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2148959%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%3C%2FP%3E%0A%3CBLOCKQUOTE%3E%0A%3CP%3E%E5%A6%82%E6%9E%9C%E6%88%91%E7%A1%AC%E9%94%81%E4%BB%BB%E4%BD%95%E4%B8%80%E4%B8%AA%E6%A8%A1%E5%9D%97%EF%BC%8C%E6%89%80%E6%9C%89%E5%85%B6%E4%BB%96%E6%A8%A1%E5%9D%97%E9%83%BD%E4%BC%9A%E8%87%AA%E5%8A%A8%E8%A2%AB%E7%A1%AC%E9%94%81%E5%AE%9A%EF%BC%8C%E8%BF%99%E5%9C%A8%E7%94%B5%E6%BA%90%E6%A8%A1%E5%BC%8F%E4%B8%8B%E4%BC%9A%E5%87%BA%E7%8E%B0%E9%97%AE%E9%A2%98%E3%80%82%E5%9B%A0%E4%B8%BA%E6%88%91%E4%B8%8D%E5%B8%8C%E6%9C%9B%20FXOSC%2FSXOSC%20%E5%92%8C%20CMU%20%E5%9C%A8%E8%BF%99%E9%87%8C%E8%A2%AB%E7%A1%AC%E9%94%81%E5%AE%9A%E3%80%82%3C%2FP%3E%0A%3C%2FBLOCKQUOTE%3E%0A%3CP%3E%E5%AF%84%E5%AD%98%E5%99%A8%E4%BF%9D%E6%8A%A4%E9%87%87%E7%94%A8%20P%20%E6%A1%A5%E3%80%82%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22petervlna_0-1754636157965.png%22%20style%3D%22width%3A%20656px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22petervlna_0-1754636157965.png%22%20style%3D%22width%3A%20656px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F351516i706250D89AE5F564%2Fimage-dimensions%2F656x397%3Fv%3Dv2%22%20width%3D%22656%22%20height%3D%22397%22%20role%3D%22button%22%20title%3D%22petervlna_0-1754636157965.png%22%20alt%3D%22petervlna_0-1754636157965.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3EPBRIDGE%20%E4%B8%8A%E6%9C%89%20MC_CGM%20%E6%A8%A1%E5%9D%97%EF%BC%9A%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22petervlna_1-1754636218800.png%22%20style%3D%22width%3A%20617px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22petervlna_1-1754636218800.png%22%20style%3D%22width%3A%20617px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F351517iEA10126CA0059023%2Fimage-dimensions%2F617x125%3Fv%3Dv2%22%20width%3D%22617%22%20height%3D%22125%22%20role%3D%22button%22%20title%3D%22petervlna_1-1754636218800.png%22%20alt%3D%22petervlna_1-1754636218800.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%E7%84%B6%E5%90%8E%E5%B0%86%E5%A4%96%E8%AE%BE%E6%98%A0%E5%B0%84%E5%88%B0%20MC_CGM%20%E4%B8%8B%E3%80%82%E7%9C%8B%E6%9D%A5%E6%82%A8%E9%9C%80%E8%A6%81%E4%BD%BF%E7%94%A8%20SLB%20%E8%80%8C%E4%B8%8D%E6%98%AF%20HLB%20%E6%9D%A5%E8%A7%A3%E5%86%B3%E8%BF%99%E4%B8%AA%E9%97%AE%E9%A2%98%E3%80%82%3C%2FP%3E%0A%3CP%3E%E5%9B%A0%E4%B8%BA%20HLB%20%E4%BC%9A%E9%94%81%E5%AE%9A%E6%95%B4%E4%B8%AA%20MC_CGM%E3%80%82%3C%2FP%3E%0A%3CP%3E%E9%A1%BA%E7%A5%9D%E5%95%86%E7%A5%BA%EF%BC%81%3C%2FP%3E%0A%3CP%3EPeter%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2148218%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Register%20Protection%20for%20MPC5746C%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2148218%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E5%97%A8%EF%BC%8C%E5%BD%BC%E5%BE%97%20%E3%80%81%3C%2FP%3E%3CP%3E%E6%84%9F%E8%B0%A2%E6%82%A8%E7%9A%84%E5%B8%AE%E5%8A%A9%E3%80%82%E6%88%91%E7%8E%B0%E5%9C%A8%E5%8F%AF%E4%BB%A5%E4%B8%BA%E6%89%80%E6%9C%89%E6%A8%A1%E5%9D%97%E9%85%8D%E7%BD%AE%E8%BD%AF%E9%94%81%E5%92%8C%E7%9B%91%E6%B5%8B%20SLB%20%E4%BA%86%E3%80%82%3C%2FP%3E%3CP%3E%E6%88%91%E8%BF%98%E6%9C%89%E4%B8%80%E4%B8%AA%E5%85%B3%E4%BA%8E%E7%A1%AC%E9%94%81%20GCR%20%E4%BD%8D%E7%9A%84%E9%97%AE%E9%A2%98%E3%80%82%E6%A0%B9%E6%8D%AE%E6%82%A8%E7%9A%84%E8%A7%A3%E9%87%8A%EF%BC%8C%E6%89%80%E6%9C%89%20MCCGM%20%E4%B8%8A%E9%99%90%E6%A8%A1%E5%9D%97%EF%BC%88%E5%8D%B3%20CMU%E3%80%81FXOSC%E3%80%81SXOSC%E3%80%81PLDIG%20%E5%92%8C%20MCCGM%EF%BC%89%E5%BA%94%E5%85%B7%E6%9C%89%E4%B8%80%E4%B8%AA%E5%85%B1%E5%90%8C%E7%9A%84%E5%9F%BA%E5%9C%B0%E5%9D%80%EF%BC%8C%E5%8D%B3%200xFFFB0000%E3%80%82%3C%2FP%3E%3CP%3E%E7%8E%B0%E5%9C%A8%E6%A0%B9%E6%8D%AE%E7%AC%AC%2077.1.1%20%E8%8A%82%E5%AF%84%E5%AD%98%E5%99%A8%E4%BF%9D%E6%8A%A4%E9%85%8D%E7%BD%AE%EF%BC%8C%3CSTRONG%3EN%3C%2FSTRONG%3E%20OTE%E8%AE%A8%E8%AE%BA%E4%BA%86%E7%94%B5%E6%BA%90%E6%A8%A1%E5%BC%8F%E4%B8%8B%E7%9A%84%E6%93%8D%E4%BD%9C%E3%80%82%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22mayank22_0-1754552830865.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22mayank22_0-1754552830865.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F351335iD3109A79A54CC80F%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22mayank22_0-1754552830865.png%22%20alt%3D%22mayank22_0-1754552830865.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%E6%AD%A3%E5%A6%82%E6%88%91%E6%89%80%E8%AF%B4%EF%BC%8C%E5%9C%A8%E7%9B%B8%E5%90%8C%E7%9A%84%E5%9F%BA%E6%9C%AC%E5%9C%B0%E5%9D%80%E4%B8%8B%EF%BC%8C%E5%A6%82%E6%9E%9C%E6%88%91%E7%A1%AC%E9%94%81%E4%BB%BB%E4%BD%95%E4%B8%80%E4%B8%AA%E6%A8%A1%E5%9D%97%EF%BC%8C%E6%89%80%E6%9C%89%E5%85%B6%E4%BB%96%E6%A8%A1%E5%9D%97%E9%83%BD%E4%BC%9A%E8%87%AA%E5%8A%A8%E8%A2%AB%E7%A1%AC%E9%94%81%E5%AE%9A%EF%BC%8C%E8%BF%99%E5%9C%A8%E4%BD%8E%E7%94%B5%E6%BA%90%E6%A8%A1%E5%BC%8F%E4%B8%8B%E4%BC%9A%E5%87%BA%E7%8E%B0%E9%97%AE%E9%A2%98%E3%80%82%E5%9B%A0%E4%B8%BA%E6%88%91%E4%B8%8D%E5%B8%8C%E6%9C%9B%20FXOSC%2FSXOSC%20%E5%92%8C%20CMU%20%E5%9C%A8%E8%BF%99%E9%87%8C%E8%A2%AB%E7%A1%AC%E9%94%81%E5%AE%9A%E3%80%82%3C%2FP%3E%3CP%3E%E6%9C%89%E6%B2%A1%E6%9C%89%E5%8A%9E%E6%B3%95%E8%A7%A3%E5%86%B3%E8%BF%99%E4%B8%AA%E9%97%AE%E9%A2%98%EF%BC%9F%3C%2FP%3E%3CP%3E%E6%84%9F%E8%B0%A2%E5%B9%B6%E8%87%B4%E6%84%8F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2144303%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Register%20Protection%20for%20MPC5746C%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2144303%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%3C%2FP%3E%0A%3CP%3E%E4%BB%A5%E4%B8%8B%E6%98%AF%20SLB%20%E7%9A%84%E7%BB%93%E6%9E%9C%20%3C%2FP%3E%0A%3CP%3ECMU_LFREFR%2032%20-%20%E5%9C%B0%E5%9D%80%E5%9F%BA%E6%95%B0%E5%92%8C%E5%81%8F%E7%A7%BB%E9%87%8F%3C%2FP%3E%0A%3CP%3ECGM%20%E6%A8%A1%E5%9D%97%E7%9A%84%E5%9F%BA%E6%95%B0%E4%B8%BA%200xFFFB_0000%3C%2FP%3E%0A%3CP%3ECMU%20%E5%81%8F%E7%A7%BB%E4%B8%BA%200x140%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22petervlna_0-1753947014813.png%22%20style%3D%22width%3A%20567px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22petervlna_0-1753947014813.png%22%20style%3D%22width%3A%20567px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F350413iD7A98F999D478088%2Fimage-dimensions%2F567x380%3Fv%3Dv2%22%20width%3D%22567%22%20height%3D%22380%22%20role%3D%22button%22%20title%3D%22petervlna_0-1753947014813.png%22%20alt%3D%22petervlna_0-1753947014813.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3ECGM%20LFREFR%20%E4%BB%8E%E6%A8%A1%E5%9D%97%E5%9F%BA%E6%95%B0%E5%81%8F%E7%A7%BB%200x14C%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22petervlna_1-1753947034996.png%22%20style%3D%22width%3A%20533px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22petervlna_1-1753947034996.png%22%20style%3D%22width%3A%20533px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F350416iEEAB267DCBDCEFAF%2Fimage-dimensions%2F533x36%3Fv%3Dv2%22%20width%3D%22533%22%20height%3D%2236%22%20role%3D%22button%22%20title%3D%22petervlna_1-1753947034996.png%22%20alt%3D%22petervlna_1-1753947034996.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22petervlna_4-1753947541951.png%22%20style%3D%22width%3A%20692px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22petervlna_4-1753947541951.png%22%20style%3D%22width%3A%20692px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F350423i29FF9F2539F3E293%2Fimage-dimensions%2F692x593%3Fv%3Dv2%22%20width%3D%22692%22%20height%3D%22593%22%20role%3D%22button%22%20title%3D%22petervlna_4-1753947541951.png%22%20alt%3D%22petervlna_4-1753947541951.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%E6%88%91%E9%80%9A%E8%BF%87%E5%86%99%E5%85%A5%E9%95%9C%E5%83%8F%E4%B8%BA%20CMU_LFREFR%20%E8%AE%BE%E7%BD%AE%E4%BA%86%20SLB%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22petervlna_3-1753947365013.png%22%20style%3D%22width%3A%20694px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22petervlna_3-1753947365013.png%22%20style%3D%22width%3A%20694px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F350420i0A4C544D39E180E1%2Fimage-dimensions%2F694x566%3Fv%3Dv2%22%20width%3D%22694%22%20height%3D%22566%22%20role%3D%22button%22%20title%3D%22petervlna_3-1753947365013.png%22%20alt%3D%22petervlna_3-1753947365013.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%E9%A1%BA%E7%A5%9D%E5%95%86%E7%A5%BA%EF%BC%81%3C%2FP%3E%0A%3CP%3EPeter%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2142720%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Register%20Protection%20for%20MPC5746C%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2142720%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E5%97%A8%EF%BC%8C%E8%BF%99%E4%B9%9F%E4%B8%8D%E8%B5%B7%E4%BD%9C%E7%94%A8%E3%80%82%3C%2FP%3E%3CDIV%3E%3CTABLE%20border%3D%221%22%20cellspacing%3D%220%22%20cellpadding%3D%220%22%3E%3CTBODY%3E%3CTR%3E%3CTD%3E%3CP%3ECMU_LFREFR%2032%3C%2FP%3E%3C%2FTD%3E%3CTD%3E%3CP%3E%E5%81%8F%E7%A7%BB%200xCh%3C%2FP%3E%3C%2FTD%3E%3CTD%3E%3CP%3E%E5%8F%97%E4%BF%9D%E6%8A%A4%E7%9A%84%E5%A4%A7%E5%B0%8F-16%EF%BC%88%E5%AD%97%E8%8A%82%202%20%E5%92%8C%203%EF%BC%89%3C%2FP%3E%3C%2FTD%3E%3C%2FTR%3E%3C%2FTBODY%3E%3C%2FTABLE%3E%3C%2FDIV%3E%3CBR%20%2F%3E%3CP%3E%3CSPAN%3E0xFFFB0000%3C%2FSPAN%3E%3CSPAN%3E%2C%3C%2FSPAN%3E%3CSPAN%3E%2F*%20CMU----------*%2F%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E5%9F%BA%E5%9C%B0%E5%9D%80%20-0xFFFB000C%3C%2FP%3E%3CP%3E%E9%95%9C%E5%83%8F%E5%9C%B0%E5%9D%80%20-0xFFFB200C%3C%2FP%3E%3CP%3ESLB%20-%200xFFFB3803%3C%2FP%3E%3CP%3EGCR%20-%200xFFFB3FFC%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22mayank22_0-1753789974341.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22mayank22_0-1753789974341.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F350024i2CCCB24F8D7A4C4A%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22mayank22_0-1753789974341.png%22%20alt%3D%22mayank22_0-1753789974341.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2142377%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Register%20Protection%20for%20MPC5746C%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2142377%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%3C%2FP%3E%0A%3CP%3E%E6%9F%A5%E7%9C%8B%E7%AE%80%E5%8D%95%E6%B5%8B%E8%AF%95%EF%BC%9A%3CSTRONG%3EMC_CMU%20-%20CSR%3C%2FSTRONG%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22petervlna_0-1753772600568.png%22%20style%3D%22width%3A%20688px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22petervlna_0-1753772600568.png%22%20style%3D%22width%3A%20688px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F349910i94B96CB2D41D49FB%2Fimage-dimensions%2F688x518%3Fv%3Dv2%22%20width%3D%22688%22%20height%3D%22518%22%20role%3D%22button%22%20title%3D%22petervlna_0-1753772600568.png%22%20alt%3D%22petervlna_0-1753772600568.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CBLOCKQUOTE%3E%0A%3CP%3E%E5%9F%BA%E5%9C%B0%E5%9D%80%20-%200xFFFB014C%20-%20%E8%BF%99%E6%98%AF%E5%81%8F%E7%A7%BB%E5%9C%B0%E5%9D%80%E3%80%82%E4%B8%8D%E6%98%AF%E5%9F%BA%E5%9C%B0%E3%80%82%3C%2FP%3E%0A%3C%2FBLOCKQUOTE%3E%0A%3CP%3EMC_CMU%20%E6%A8%A1%E5%9D%97%E7%9A%84%E5%9F%BA%E6%95%B0%E4%B8%BA%200xFFFB%200140%E3%80%82%3C%2FP%3E%0A%3CBLOCKQUOTE%3E%0A%3CP%3E%E9%95%9C%E5%83%8F%E5%9C%B0%E5%9D%80%20-0xFFFB214C%20%3C%2FP%3E%0A%3C%2FBLOCKQUOTE%3E%0A%3CP%3E%E5%8D%B3%E5%9F%BA%E5%BA%A7%20%2B%20%E5%81%8F%E7%A7%BB%20%2B%20%E9%95%9C%E5%83%8F%3C%2FP%3E%0A%3CBLOCKQUOTE%3E%0A%3CP%3ESLB%20-0xFFFB3943%3C%2FP%3E%0A%3C%2FBLOCKQUOTE%3E%0A%3CP%3E%E4%BB%A5%E5%8F%82%E8%80%83%E6%89%8B%E5%86%8C%E4%B8%AD%E7%9A%84%E6%95%B4%E4%B8%AA%20CGM%20%E7%9A%84%E5%9C%B0%E5%9D%80%E4%B8%BA%E5%9F%BA%E5%87%86%EF%BC%9A%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22petervlna_1-1753772881109.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22petervlna_1-1753772881109.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F349911iB7BB0E09733E307F%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22petervlna_1-1753772881109.png%22%20alt%3D%22petervlna_1-1753772881109.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%E6%89%80%E4%BB%A5%E8%AE%A1%E7%AE%97%E7%BB%93%E6%9E%9C%E6%98%AF%3C%2FP%3E%0A%3CP%3E0xFFFB0000%20%2B%203800%20%2B%20SLB%20%E7%9A%84%E4%BD%8D%E7%BD%AE%3C%2FP%3E%0A%3CBLOCKQUOTE%3E%0A%3CP%3EGCR%20-%200xFFFB413C%3C%2FP%3E%0A%3C%2FBLOCKQUOTE%3E%0A%3CP%3E%E5%90%8C%E4%B8%8A%3C%2FP%3E%0A%3CP%3E0xFFFB0000%2B3FF0%3C%2FP%3E%0A%3CP%3E%E9%A1%BA%E7%A5%9D%E5%95%86%E7%A5%BA%EF%BC%81%3C%2FP%3E%0A%3CP%3EPeter%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2141717%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Register%20Protection%20for%20MPC5746C%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2141717%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E5%97%A8%EF%BC%8C%E5%BD%BC%E5%BE%97%EF%BC%8C%E8%BF%99%E9%87%8C%E6%9C%89%E4%B8%80%E4%BA%9B%20SLB%20%E5%92%8C%20GCR%20%E5%A4%B1%E6%95%88%E7%9A%84%E7%A4%BA%E4%BE%8B%E3%80%82%20%E8%AF%B7%E6%A3%80%E6%9F%A5%E8%BF%99%E4%BA%9B%E5%9C%B0%E5%9D%80%E5%B9%B6%E7%A1%AE%E8%AE%A4%E5%AE%83%E4%BB%AC%E6%98%AF%E5%90%A6%E6%98%BE%E7%A4%BA%E4%B8%8D%E5%90%8C%E7%9A%84%E8%A1%8C%E4%B8%BA%E3%80%82%E5%A6%82%E6%9E%9C%E4%B8%8D%E6%98%AF%EF%BC%8C%E9%82%A3%E4%B9%88%E8%BF%99%E4%BA%9B%E6%A8%A1%E5%9D%97%E4%BC%9A%E6%9C%89%E4%BB%80%E4%B9%88%E9%97%AE%E9%A2%98%EF%BC%9F%3C%2FP%3E%3CP%3E%3CSTRONG%3E1.MC_CMU%20-%200xFFFB0140%20-%20%7B%20MODULE_CMU%2C%200xC%2CREG_SIZE_16%7D%2C%20CMU_LFREFR%3C%2FSTRONG%3E%3C%2FP%3E%3COL%3E%3COL%3E%3CLI%3E%E5%9F%BA%E5%9C%B0%E5%9D%80%20-%200xFFFB014C%3C%2FLI%3E%3CLI%3E%E9%95%9C%E5%83%8F%E5%9C%B0%E5%9D%80%20-0xFFFB214C%3C%2FLI%3E%3CLI%3ESLB%20-0xFFFB3943%3C%2FLI%3E%3CLI%3EGCR%20-%200xFFFB413C%3C%2FLI%3E%3C%2FOL%3E%3C%2FOL%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22mayank22_0-1753700010986.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22mayank22_0-1753700010986.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F349738i28D614B3FADD7F78%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22mayank22_0-1753700010986.png%22%20alt%3D%22mayank22_0-1753700010986.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E2.MC_CMU%20-%200xFFFB0140%20%7B%20MODULE_CMU%2C%200x18%2CREG_SIZE_32%7D%2C%20CMU_MDR%3C%2FSTRONG%3E%3C%2FP%3E%3COL%3E%3COL%3E%3CLI%3E%E5%9F%BA%E6%9C%AC%E5%9C%B0%E5%9D%80%20-%200xFFFB0158%3C%2FLI%3E%3CLI%3E%E9%95%9C%E5%83%8F%E5%9C%B0%E5%9D%80%20-%200xFFFB2158%3C%2FLI%3E%3CLI%3ESLB%20-%200xFFFB3946%3C%2FLI%3E%3CLI%3EGCR%20-%200xFFFB413C%3C%2FLI%3E%3C%2FOL%3E%3C%2FOL%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22mayank22_1-1753700066515.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22mayank22_1-1753700066515.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F349739i410E737E6C625C2D%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22mayank22_1-1753700066515.png%22%20alt%3D%22mayank22_1-1753700066515.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E3.PLLDIG%200xFFFB0080%20-%20PLLDIG_PLLCR%20%3C%2FSPAN%3E%3CSPAN%3E%7B%20MODULE_PLLDIG%2C%200x20%2C%20REG_SIZE_16%7D%2C%20PLLDIG_PLLCR%3C%2FSPAN%3E%3C%2FP%3E%3COL%3E%3COL%3E%3CLI%3E%3CSPAN%3E%E5%9F%BA%E6%9C%AC%E5%9C%B0%E5%9D%80%20-%200xFFFB00A0%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%3E%3CSPAN%3E%E9%95%9C%E5%83%8F%E5%9C%B0%E5%9D%80%20-%200xFFFB20A0%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%3E%3CSPAN%3ESLB%20-%200xFFFB0F5D%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%3E%3CSPAN%3EGCR%20-%200xFFFB407C%3C%2FSPAN%3E%3C%2FLI%3E%3C%2FOL%3E%3C%2FOL%3E%3CBR%20%2F%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22mayank22_4-1753700213295.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22mayank22_4-1753700213295.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F349742i6A990F5E7D2A8E8A%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22mayank22_4-1753700213295.png%22%20alt%3D%22mayank22_4-1753700213295.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%3CSPAN%3E4.PLLDIG%200xFFFB0080%20-%20%7B%20MODULE_PLLDIG%2C%200x28%2CREG_SIZE_32%7D.%20%3C%2FSPAN%3E%3CSPAN%3E%7B%20MODULE_PLLDIG%2C%200x28%2CREG_SIZE_32%7D%2C%20PLLDIG_PLLDV%3C%2FSPAN%3E%3C%2FP%3E%3COL%3E%3COL%3E%3CLI%3E%3CSPAN%3E%E5%9F%BA%E6%9C%AC%E5%9C%B0%E5%9D%80%20-%200xFFFB00A8%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%3E%3CSPAN%3E%E9%95%9C%E5%83%8F%E5%9C%B0%E5%9D%80%20-%200xFFFB20A8%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%3E%3CSPAN%3ESLB%20-%200xFFFB388A%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%3E%3CSPAN%3EGCR%20-%200xFFFB407C%3C%2FSPAN%3E%3C%2FLI%3E%3C%2FOL%3E%3C%2FOL%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22mayank22_5-1753700236791.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22mayank22_5-1753700236791.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F349743i93B95E43200B3947%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22mayank22_5-1753700236791.png%22%20alt%3D%22mayank22_5-1753700236791.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%3CSPAN%3E5.PMCDIG%200xFFFA0400%20-%20%7B%20MODULE_PMCDIG%2C%200x0%2CREG_SIZE_32%7D.%20%3C%2FSPAN%3E%3CSPAN%3E%7B%20MODULE_PMCDIG%2C%200x0%2CREG_SIZE_32%7D%E3%80%81%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3COL%3E%3CLI%3E%3CSPAN%3E%E5%9F%BA%E6%9C%AC%E5%9C%B0%E5%9D%80%20-%200xFFFA0400%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%3E%3CSPAN%3E%E9%95%9C%E5%83%8F%E5%9C%B0%E5%9D%80%20-%200xFFFA2400%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%3E%3CSPAN%3ESLB%20-%200xFFFA3C00%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%3E%3CSPAN%3EGCR%20-%200xFFFA43FC%3C%2FSPAN%3E%3C%2FLI%3E%3C%2FOL%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22mayank22_6-1753700259740.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22mayank22_6-1753700259740.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F349744iBD1D73C45A6752D6%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22mayank22_6-1753700259740.png%22%20alt%3D%22mayank22_6-1753700259740.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E6.PMCDIG%200xFFFA0400%20-%20%7B%20MODULE_PMCDIG%2C%200x10%2CREG_SIZE_32%7D.%3C%2FSPAN%3E%3CSPAN%3E%7B%20MODULE_PMCDIG%2C%200x10%2CREG_SIZE_32%7D%E3%80%81%3C%2FSPAN%3E%3C%2FP%3E%3COL%3E%3COL%3E%3CLI%3E%3CSPAN%3E%E5%9F%BA%E6%9C%AC%E5%9C%B0%E5%9D%80%20-%200xFFFA0410%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%3E%3CSPAN%3E%E9%95%9C%E5%83%8F%E5%9C%B0%E5%9D%80%20-%200xFFFA2410%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%3E%3CSPAN%3ESLB%20-%200xFFFA3C04%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%3E%3CSPAN%3EGCR%20-%200xFFFA43FC%3C%2FSPAN%3E%3C%2FLI%3E%3C%2FOL%3E%3C%2FOL%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22mayank22_7-1753700335502.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22mayank22_7-1753700335502.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F349745iB90FBE11455C9A5C%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22mayank22_7-1753700335502.png%22%20alt%3D%22mayank22_7-1753700335502.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2138200%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Register%20Protection%20for%20MPC5746C%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2138200%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%3C%2FP%3E%0A%3CP%3E%E6%88%91%E5%B7%B2%E7%BB%8F%E6%A3%80%E6%9F%A5%E4%BA%86%20PREG_PROT%EF%BC%8C%E5%AE%83%E7%9A%84%E8%A1%8C%E4%B8%BA%E5%B0%B1%E5%83%8F%E5%8F%82%E8%80%83%E6%89%8B%E5%86%8C%E4%B8%AD%E6%8F%8F%E8%BF%B0%E7%9A%84%E9%82%A3%E6%A0%B7%EF%BC%9A%3C%2FP%3E%0A%3CP%3E%E5%9C%A8%20ME_CGM%20%E5%AF%84%E5%AD%98%E5%99%A8%20SC_DC0%20%E4%B8%8A%EF%BC%9A%3C%2FP%3E%0A%3CP%3E%E5%9F%BA%E6%95%B0%EF%BC%9A0xFFFB0000%20%2B%20%E5%81%8F%E7%A7%BB%207E8%3C%2FP%3E%0A%3CP%3E%E9%95%9C%E5%83%8F0xFFFB07E8%3C%2FP%3E%0A%3CP%3E%3D%20%E5%9F%BA%E6%95%B0%20(0xFFFB0000)%20%2B%20%E5%81%8F%E7%A7%BB%20(7E8)%20%2B%20%E9%95%9C%E5%83%8F%20(0x2000)%3C%2FP%3E%0A%3CP%3E%E5%9C%A8%E7%A4%BA%E4%BE%8B%E4%B8%AD%EF%BC%8C%E6%88%91%E9%80%9A%E8%BF%87%E8%BD%AF%E9%94%81%E9%94%81%E5%AE%9A%E4%BA%86%20SC_DC0%20%E5%BD%A2%E5%BC%8F%E7%9A%84%20ME_CGM%20%E6%A8%A1%E5%9D%97%E3%80%82%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22petervlna_0-1753172674705.png%22%20style%3D%22width%3A%20866px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22petervlna_0-1753172674705.png%22%20style%3D%22width%3A%20866px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F348779i46AE5F42B8B3D3C7%2Fimage-dimensions%2F866x546%3Fv%3Dv2%22%20width%3D%22866%22%20height%3D%22546%22%20role%3D%22button%22%20title%3D%22petervlna_0-1753172674705.png%22%20alt%3D%22petervlna_0-1753172674705.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%E5%85%B7%E4%BD%93%E6%83%85%E5%86%B5%E5%A6%82%E4%B8%8B%EF%BC%9A%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22petervlna_1-1753172729779.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22petervlna_1-1753172729779.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F348781i326E34F1C5C3B462%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22petervlna_1-1753172729779.png%22%20alt%3D%22petervlna_1-1753172729779.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%E5%8C%BA%E5%9F%9F%204%EF%BC%9A%E4%B8%BA%201.5%20KB%EF%BC%8C%E5%8C%85%E5%90%AB%E8%BD%AF%E9%94%81%E4%BD%8D%EF%BC%8C%3CSTRONG%3E%E5%8C%BA%E5%9F%9F%201%20%E4%B8%AD%E6%AF%8F%E5%AD%97%E8%8A%82%E4%B8%80%3C%2FSTRONG%3E%E4%BD%8D%E3%80%82%E4%B8%8E%E4%B8%80%E4%B8%AA%E6%A8%A1%E5%9D%97%E5%AF%84%E5%AD%98%E5%99%A8%E5%AD%97%E7%9B%B8%E5%85%B3%E7%9A%84%E5%9B%9B%E4%B8%AA%E8%BD%AF%E9%94%81%E4%BD%8D%E6%8E%92%E5%88%97%E5%9C%A8%E5%AD%98%E5%82%A8%E5%99%A8%E6%98%A0%E5%B0%84%E4%B8%AD%E7%9A%84%E5%AD%97%E8%8A%82%E8%BE%B9%E7%95%8C%E5%A4%84%E3%80%82%E8%BD%AF%E9%94%81%E5%AE%9A%E4%BD%8D%E5%AF%84%E5%AD%98%E5%99%A8%E5%8F%AF%E4%BD%BF%E7%94%A8%E4%BD%8D%E6%8E%A9%E7%A0%81%E7%9B%B4%E6%8E%A5%E5%86%99%E5%85%A5%E3%80%82%3C%2FP%3E%0A%3CP%3E%E5%9B%A0%E6%AD%A4%EF%BC%8C%E5%BF%85%E9%A1%BB%E5%B0%86%E8%BD%AF%E9%94%81%E5%AE%9A%E4%BD%8D%E7%9A%84%E9%9D%A2%E7%A7%AF%E9%99%A4%E4%BB%A5%208%EF%BC%8C%E6%89%8D%E8%83%BD%E7%9C%8B%E5%88%B0%E7%9B%B8%E5%BA%94%E7%9A%84%20SLB%20%E8%AE%BE%E7%BD%AE%E3%80%82%3C%2FP%3E%0A%3CP%3E%E5%9F%BA%E7%A1%80%EF%BC%88%E6%A8%A1%E5%9D%97%E7%9A%84%EF%BC%89%2B%203800%20%2B%EF%BC%88%E5%8C%BA%E5%9F%9F%201%20%E7%9A%84%E6%AF%8F%E5%AD%97%E8%8A%82%E4%B8%80%E4%BD%8D%EF%BC%89%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22petervlna_2-1753172994361.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22petervlna_2-1753172994361.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F348784i240EEAB8DF9D050A%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22petervlna_2-1753172994361.png%22%20alt%3D%22petervlna_2-1753172994361.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22petervlna_3-1753173019294.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22petervlna_3-1753173019294.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F348785i304A6C887FC2D0D0%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22petervlna_3-1753173019294.png%22%20alt%3D%22petervlna_3-1753173019294.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%E5%AF%B9%E4%BA%8E%E7%A1%AC%E9%94%81%E4%BD%8D%EF%BC%8C%E6%95%B4%E4%B8%AA%E6%A8%A1%E5%9D%97%E5%8F%AA%E6%9C%89%E4%B8%80%E4%B8%AA%E3%80%82%3C%2FP%3E%0A%3CP%3E%E5%8C%BA%E5%9F%9F%205%20%E7%9A%84%E5%A4%A7%E5%B0%8F%E4%B8%BA%20512%20%E5%AD%97%E8%8A%82%EF%BC%8C%E7%94%A8%E4%BA%8E%E4%BF%9D%E5%AD%98%E4%BF%9D%E6%8A%A4%E6%A8%A1%E5%BC%8F%E7%9A%84%E9%85%8D%E7%BD%AE%E4%BD%8D%E3%80%82%3CSTRONG%3E%E6%AF%8F%E4%B8%AA%E6%A8%A1%E5%9D%97%E9%83%BD%E6%9C%89%E4%B8%80%E4%B8%AA%E9%85%8D%E7%BD%AE%E7%A1%AC%E9%94%81%E4%BD%8D%3C%2FSTRONG%3E%EF%BC%8C%E5%8F%AF%E4%BB%A5%E9%98%B2%E6%AD%A2%E5%AF%B9%E8%BD%AF%E9%94%81%E4%BD%8D%E8%BF%9B%E8%A1%8C%E4%BB%BB%E4%BD%95%E8%BF%9B%E4%B8%80%E6%AD%A5%E7%9A%84%E4%BF%AE%E6%94%B9%EF%BC%8C%E5%B9%B6%E4%B8%94%E5%8F%AA%E8%83%BD%E5%9C%A8%E8%AE%BE%E7%BD%AE%E5%90%8E%E9%80%9A%E8%BF%87%E7%B3%BB%E7%BB%9F%20RESET%20%E6%9D%A5%E6%B8%85%E9%99%A4%E3%80%82%E5%85%B6%E4%BB%96%E4%BD%8D%E5%A6%82%E6%9E%9C%E8%A2%AB%E8%AE%BE%E7%BD%AE%EF%BC%8C%E5%B0%86%E5%85%81%E8%AE%B8%E7%94%A8%E6%88%B7%E8%AE%BF%E9%97%AE%E5%8F%97%E4%BF%9D%E6%8A%A4%E7%9A%84%E6%A8%A1%E5%9D%97%E3%80%82%3C%2FP%3E%0A%3CP%3E%E5%9F%BA%E6%95%B0%EF%BC%88%E6%A8%A1%E5%9D%97%EF%BC%89%200xFFFB0000%20%2B%20%E5%81%8F%E7%A7%BB%203FFC%3C%2FP%3E%0A%3CP%3E%E5%9B%A0%E4%B8%BA%20GCR%20%E4%BD%8D%E4%BA%8E%205%20%E5%8F%B7%E5%8C%BA%E5%9F%9F%E7%9A%84%E6%9C%AB%E7%AB%AF%E3%80%82%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22petervlna_5-1753173243793.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22petervlna_5-1753173243793.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F348790i784C0BF514985C8D%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22petervlna_5-1753173243793.png%22%20alt%3D%22petervlna_5-1753173243793.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22petervlna_4-1753173057363.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22petervlna_4-1753173057363.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F348786i3FC76DED2F2D5723%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22petervlna_4-1753173057363.png%22%20alt%3D%22petervlna_4-1753173057363.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E9%A1%BA%E7%A5%9D%E5%95%86%E7%A5%BA%EF%BC%81%3C%2FP%3E%0A%3CP%3EPeter%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2136474%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Register%20Protection%20for%20MPC5746C%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2136474%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%3C%2FP%3E%0A%3CP%3E%E6%88%91%E4%BC%9A%E8%BF%9B%E8%A1%8C%E6%B5%8B%E8%AF%95%EF%BC%8C%E5%B9%B6%E5%B0%BD%E5%BF%AB%E7%BB%99%E6%82%A8%E7%AD%94%E5%A4%8D%E3%80%82%3C%2FP%3E%0A%3CP%3E%E9%A1%BA%E7%A5%9D%E5%95%86%E7%A5%BA%EF%BC%81%3C%2FP%3E%0A%3CP%3EPeter%3C%2FP%3E%3C%2FLINGO-BODY%3E
