RAppID BL Tool
RAppID BL Tool
6,027 次查看
ahmetsaglam
Hi, @mariuslucianand
Who from NXP can help us with the open-source codes of the RApID bootloader program? We want to install software via RAppId with PCAN.
We spoke to Vector and they reported that it has been discontinued for CanCase Xl.
Best Regards.
5,969 次查看
lukaszadrapa
On the RAppID BL application, please choose "Vector CANCaseXL".
Lukas
5 回复数
5,060 次查看
nailgg
I also needed to use the RAppID BL software with my PCAN adapter. Slightly modified the RAppID_BL.exe to make it work with PCAN, binary can be found in the attachment. The app thinks it's Vector so Vector CANCaseXL must be chosen, but it actually sends the messages to the Peak adapter.
I needed this to test to see whether my SPC560P50 will work with the bootloaders in this software. I tried MPC5604/3P, it successfully uploads the BL but then it gets stuck in the Initialization phase for some reason. Been trying to figure out why for a few days but I think I'll give up so I hope this at least works for someone else.
6,009 次查看
lukaszadrapa
Hi Ahmet,
Rappid bootloader is not an open source, we do not provide the source codes due to legal reasons.
Even if Vector tools are discontinued, we confirmed that new VN16xx tools from Vector are compatible and those can be used with Rappid bootloader.
Lukas
5,708 次查看
setsaillove
Hello :
I do not know how to get the RAppID BL Tool.
could you please share the download address about RAppID BL Tool?
5,986 次查看
ahmetsaglam
Hi @lukaszadrapa
We have a Vector-VN1630.
We made Vector hardware configuration.
But we can't see Vn1630 in the program. Which one should we choose?
5,970 次查看
lukaszadrapa
Lukas
