Question about the MPC5748G ULPI0_Data interface output
ソリューションへジャンプ
3,245件の閲覧回数
H-chips
Dear NXP Community,
  When I used the USB0 interface of MPC5748G, after enabling the clock and interface, I used the oscilloscope to detect the potential of ULPI0_Data[0:7] as follows:
ULPI0_Data[0]: 3.3v
ULPI0_Data[1]: 0v
ULPI0_Data[2]: 3.3v
ULPI0_Data[3]: 0v
ULPI0_Data[4]: 0v
ULPI0_Data[5]: 0v
ULPI0_Data[6]: 1v
ULPI0_Data[7]: 1v
  These levels do not change, which is a stable continuous voltage waveform. I think only enable the case of the clock, should be idle state, idle state is Low? Is there a problem here?
  Second, is the voltage at ULPI0_Data[6:7] a normal voltage?
  All of these outputs are LOW until the clock is enabled.
  Looking forward to your help!
H-chips
3,143件の閲覧回数
PetrS
MCU drives TX CMD on data lines but NXT is driven by PHY, so if TX CMD is proper, rather consult USB3340 datasheet for detailed info.
BR, Petr
5 返答(返信)
3,182件の閲覧回数
PetrS
ULPI0_Data are bidirectional pins, question could be who is driving it. 1V does not seems to be correct voltage. Is there any device connected to ULPI interface? What about other signals (DIR, NXT, STP)?
The RM indicates DIR pin should have weak pull down enabled, so check that.
BR, Petr
3,152件の閲覧回数
H-chips
Hello, I have found that Data[6] and Data[7] are short-circuited, resulting in both performances of 1V.
But the new problem is that after sending the TXD CMD, the USB controller (USB3340) does not pull the NXT up. What are the possibilities?
3,144件の閲覧回数
PetrS
BR, Petr
3,096件の閲覧回数
H-chips
Ok, thank you very much, I will check this topic.
3,167件の閲覧回数
H-chips
Thank you very much for your answer. I will check it over here.
%3CLINGO-SUB%20id%3D%22lingo-sub-1997642%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EMPC5748G%20ULPI0_Data%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%95%E3%82%A7%E3%83%BC%E3%82%B9%E3%81%AE%E5%87%BA%E5%8A%9B%E3%81%AB%E9%96%A2%E3%81%99%E3%82%8B%E8%B3%AA%E5%95%8F%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1997642%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E8%A6%AA%E6%84%9B%E3%81%AA%E3%82%8BNXP%E3%82%B3%E3%83%9F%E3%83%A5%E3%83%8B%E3%83%86%E3%82%A3%E3%81%AE%E7%9A%86%E6%A7%98%E3%80%81%3C%2FP%3E%3CP%3EMPC5748G%E3%81%AEUSB0%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%95%E3%82%A7%E3%83%BC%E3%82%B9%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%9F%E5%A0%B4%E5%90%88%E3%80%81%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%E3%81%A8%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%95%E3%82%A7%E3%83%BC%E3%82%B9%E3%82%92%E6%9C%89%E5%8A%B9%E3%81%AB%E3%81%97%E3%81%9F%E5%BE%8C%E3%80%81%E3%82%AA%E3%82%B7%E3%83%AD%E3%82%B9%E3%82%B3%E3%83%BC%E3%83%97%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E6%AC%A1%E3%81%AE%E3%82%88%E3%81%86%E3%81%ABULPI0_Data%5B0%3A7%5D%E3%81%AE%E9%9B%BB%E4%BD%8D%E3%82%92%E6%A4%9C%E5%87%BA%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3EULPI0_Data%5B0%5D%3A%203.3v%3CBR%20%2F%3EULPI0_Data%5B1%5D%3A%200v%3CBR%20%2F%3EULPI0_Data%5B2%5D%3A%203.3v%3CBR%20%2F%3EULPI0_Data%5B3%5D%3A%200v%3CBR%20%2F%3EULPI0_Data%5B4%5D%3A%200v%3CBR%20%2F%3EULPI0_Data%5B5%5D%3A%200v%3CBR%20%2F%3EULPI0_Data%5B6%5D%3A%201v%3CBR%20%2F%3EULPI0_Data%5B7%5D%3A%201v%3C%2FP%3E%3CP%3E%E3%81%93%E3%82%8C%E3%82%89%E3%81%AE%E3%83%AC%E3%83%99%E3%83%AB%E3%81%AF%E5%A4%89%E5%8C%96%E3%81%9B%E3%81%9A%E3%80%81%E5%AE%89%E5%AE%9A%E3%81%97%E3%81%9F%E9%80%A3%E7%B6%9A%E9%9B%BB%E5%9C%A7%E6%B3%A2%E5%BD%A2%E3%81%A7%E3%81%99%E3%80%82%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%E3%81%AE%E5%A0%B4%E5%90%88%E3%81%AE%E3%81%BF%E6%9C%89%E5%8A%B9%E3%81%AB%E3%81%99%E3%82%8B%E3%81%A8%E6%80%9D%E3%81%84%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81%E3%82%A2%E3%82%A4%E3%83%89%E3%83%AB%E7%8A%B6%E6%85%8B%E3%81%AF%E3%83%AD%E3%83%BC%E3%81%A7%E3%81%82%E3%82%8B%E3%81%B9%E3%81%8D%E3%81%A7%E3%81%99%E3%81%8B%3F%E3%81%93%E3%81%93%E3%81%AB%E5%95%8F%E9%A1%8C%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E6%AC%A1%E3%81%AB%E3%80%81ULPI0_Data%5B6%3A7%5D%E3%81%AE%E9%9B%BB%E5%9C%A7%E3%81%AF%E6%AD%A3%E5%B8%B8%E3%81%AA%E9%9B%BB%E5%9C%A7%E3%81%A7%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3CP%3E%E3%81%93%E3%82%8C%E3%82%89%E3%81%AE%E5%87%BA%E5%8A%9B%E3%81%AF%E3%81%99%E3%81%B9%E3%81%A6%E3%80%81%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%E3%81%8C%E3%82%A4%E3%83%8D%E3%83%BC%E3%83%96%E3%83%AB%E3%81%95%E3%82%8C%E3%82%8B%E3%81%BE%E3%81%A7LOW%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%81%82%E3%81%AA%E3%81%9F%E3%81%AE%E5%8A%A9%E3%81%91%E3%82%92%E6%A5%BD%E3%81%97%E3%81%BF%E3%81%AB%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99!%3C%2FP%3E%3CBR%20%2F%3E%3CP%3EH%E3%83%81%E3%83%83%E3%83%97%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2004625%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3AMPC5748G%20ULPI0_Data%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%95%E3%82%A7%E3%83%BC%E3%82%B9%E5%87%BA%E5%8A%9B%E3%81%AB%E9%96%A2%E3%81%99%E3%82%8B%E8%B3%AA%E5%95%8F%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2004625%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E3%82%8F%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%E3%80%81%E3%81%A9%E3%81%86%E3%82%82%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%97%E3%81%9F%E3%80%81%E3%81%93%E3%81%AE%E3%83%88%E3%83%94%E3%83%83%E3%82%AF%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2004387%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3AMPC5748G%20ULPI0_Data%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%95%E3%82%A7%E3%83%BC%E3%82%B9%E5%87%BA%E5%8A%9B%E3%81%AB%E9%96%A2%E3%81%99%E3%82%8B%E8%B3%AA%E5%95%8F%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2004387%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%2C%3C%2FP%3E%0A%3CP%3EMCU%E3%81%AF%E3%83%87%E3%83%BC%E3%82%BF%E3%83%A9%E3%82%A4%E3%83%B3%E4%B8%8A%E3%81%A7TX%20CMD%E3%82%92%E9%A7%86%E5%8B%95%E3%81%97%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81NXT%E3%81%AFPHY%E3%81%AB%E3%82%88%E3%81%A3%E3%81%A6%E9%A7%86%E5%8B%95%E3%81%95%E3%82%8C%E3%82%8B%E3%81%9F%E3%82%81%E3%80%81TX%20CMD%E3%81%8C%E9%81%A9%E5%88%87%E3%81%AA%E5%A0%B4%E5%90%88%E3%81%AF%E3%80%81USB3340%E3%83%87%E3%83%BC%E3%82%BF%E3%82%B7%E3%83%BC%E3%83%88%E3%81%A7%20%3CSPAN%3E%E8%A9%B3%E7%B4%B0%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3EBR%2C%20Petr%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2003620%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3AMPC5748G%20ULPI0_Data%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%95%E3%82%A7%E3%83%BC%E3%82%B9%E5%87%BA%E5%8A%9B%E3%81%AB%E9%96%A2%E3%81%99%E3%82%8B%E8%B3%AA%E5%95%8F%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2003620%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81Data%5B6%5D%E3%81%A8Data%5B7%5D%E3%81%8C%E7%9F%AD%E7%B5%A1%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%81%9F%E3%82%81%E3%80%81%E4%B8%A1%E6%96%B9%E3%81%AE%E3%83%91%E3%83%95%E3%82%A9%E3%83%BC%E3%83%9E%E3%83%B3%E3%82%B9%E3%81%8C1V%E3%81%AB%E3%81%AA%E3%81%A3%E3%81%A6%E3%81%84%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E3%82%8F%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%E3%81%97%E3%81%8B%E3%81%97%E3%80%81%E6%96%B0%E3%81%97%E3%81%84%E5%95%8F%E9%A1%8C%E3%81%AF%E3%80%81TXD%20CMD%20%E3%82%92%E9%80%81%E4%BF%A1%E3%81%97%E3%81%9F%E5%BE%8C%E3%80%81USB%20%E3%82%B3%E3%83%B3%E3%83%88%E3%83%AD%E3%83%BC%E3%83%A9%E3%83%BC%20(USB3340)%20%E3%81%8C%20NXT%20%E3%82%92%E3%83%97%E3%83%AB%E3%82%A2%E3%83%83%E3%83%97%E3%81%97%E3%81%AA%E3%81%84%E3%81%93%E3%81%A8%E3%81%A7%E3%81%99%E3%80%82%E3%81%A9%E3%81%AE%E3%82%88%E3%81%86%E3%81%AA%E5%8F%AF%E8%83%BD%E6%80%A7%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2002729%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3AMPC5748G%20ULPI0_Data%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%95%E3%82%A7%E3%83%BC%E3%82%B9%E5%87%BA%E5%8A%9B%E3%81%AB%E9%96%A2%E3%81%99%E3%82%8B%E8%B3%AA%E5%95%8F%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2002729%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E3%81%94%E5%9B%9E%E7%AD%94%E3%81%84%E3%81%9F%E3%81%A0%E3%81%8D%E3%80%81%E8%AA%A0%E3%81%AB%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%81%93%E3%81%A1%E3%82%89%E3%81%A7%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%A6%E3%81%BF%E3%81%BE%E3%81%99%E3%80%82%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2002002%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3AMPC5748G%20ULPI0_Data%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%95%E3%82%A7%E3%83%BC%E3%82%B9%E5%87%BA%E5%8A%9B%E3%81%AB%E9%96%A2%E3%81%99%E3%82%8B%E8%B3%AA%E5%95%8F%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2002002%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%2C%3C%2FP%3E%0A%3CP%3E%3CSPAN%3EULPI0_Data%E3%80%81%E5%8F%8C%E6%96%B9%E5%90%91%E3%83%94%E3%83%B3%E3%81%AE%E5%A0%B4%E5%90%88%E3%80%81%E8%AA%B0%E3%81%8C%E3%81%9D%E3%82%8C%E3%82%92%E9%A7%86%E5%8B%95%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%81%AE%E3%81%8B%E3%81%8C%E5%95%8F%E9%A1%8C%E3%81%AB%E3%81%AA%E3%82%8B%E5%8F%AF%E8%83%BD%E6%80%A7%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%821V%E3%81%AF%E6%AD%A3%E3%81%97%E3%81%84%E9%9B%BB%E5%9C%A7%E3%81%A7%E3%81%AF%E3%81%AA%E3%81%84%E3%82%88%E3%81%86%E3%81%A7%E3%81%99%E3%80%82%3C%2FSPAN%3EULPI%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%95%E3%82%A7%E3%83%BC%E3%82%B9%E3%81%AB%E6%8E%A5%E7%B6%9A%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8B%3F%E3%81%9D%E3%81%AE%E4%BB%96%E3%81%AE%E4%BF%A1%E5%8F%B7(DIR%E3%80%81NXT%E3%80%81STP)%E3%81%AF%E3%81%A9%E3%81%86%E3%81%A7%E3%81%99%E3%81%8B%3F%3CBR%20%2F%3ERM%20%E3%81%AF%E3%80%81DIR%20%E3%83%94%E3%83%B3%E3%81%A7%E5%BC%B1%E3%81%84%E3%83%97%E3%83%AB%E3%83%80%E3%82%A6%E3%83%B3%E3%81%8C%E6%9C%89%E5%8A%B9%E3%81%AB%E3%81%AA%E3%81%A3%E3%81%A6%E3%81%84%E3%82%8B%E3%81%93%E3%81%A8%E3%82%92%E7%A4%BA%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%81%AE%E3%81%A7%E3%80%81%E3%81%9D%E3%82%8C%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%0A%3CP%3EBR%2C%20Petr%3C%2FP%3E%0A%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E
