Query regarding cascading the boards
Varun_V_Sharma
We are trying to have an evaluation board which can manage 20 LiFePO cells in series and would like to know whether MPC5775E-EVB can be cascaded to serve this purpose. If yes, kindly indicate the steps to be followed.
Thanks and regards
Varun_V_Sharma
thank you so much for the info. this will be helpful
Varun_V_Sharma
thank you so much
petervlna
Have a look at the dev kit board with MPC5775E:
https://www.nxp.com/design/designs/mpc5775b-bms-and-vcu-reference-design:RDVCU5775EVM
The system mainly consists of a master board and several slave boards connected in series with a daisy-chain with TPL.
To MC33771 - you can connect up to 14 cells.
You can also consider a design with S32K3xx which is more advanced microcontroller:
https://www.nxp.com/design/designs/hvbms-reference-design-bundle-using-etpl:RD-HVBMSCTBUN
Peter
