Programming and debugging using MPC5748G DevKit
1,363件の閲覧回数
anniepaul
I tried to load a sample project of MPC5748G in to the Devkit. But I am getting the following issue and hence not able to run the program.
 Warning: the current language does not match this frame.
No source file named D:\\NXP\\sample\\sample_Z4_1\\src\\main_Z4_1.c.
But the main_Z4_1.c file is available in the above location.
1,242件の閲覧回数
martin_kovar
could you please write me, what project you try to download into the microcontroller? Which version of S32 Design Studio you use?
Could you please share the error screen?
Martin
