Problem About Debugging on EVB of MPC5744P
1,646件の閲覧回数
hbw
Recently,I am learning MPC5744P.However,I can not debug it by S32 IDE normally.The problem is as follows:
     After I Click "Debug" button,it will appear the Dialog as below:
Then,it will appear:
Finally,the debug is aborted.
Hoping can be solved,thanks!
Best Wishes!
2 返答(返信)
1,469件の閲覧回数
hbw
     Excited! The problem has been solved.I change my IDE into S32  for Power IDE 1.2 version.Then the problem is solved.
I think the problem may be duo to the compatibility between IDE and Debug emulator.
     That's all.
1,469件の閲覧回数
hbw
There are pictures:
