PLL Setting for Multiplier Values
ソリューションへジャンプ
1,649件の閲覧回数
berat24
Hello everyone,
When I looked at the clock generation diagram for MCU5777C, there is a multiplier separately for PLL0 and PLL1. However, I could not find the relevant register in order to edit multiplier value.
Could you show me which registers are about that.
Note : I did all divider settings with correct registers but these registers do not have any bit for multipliers.
Thank you in advance:)
1,644件の閲覧回数
PetrS
see MFD fields of PLLDIG_PLL0DV and PLLDIG_PLL1DV registers.
BR, Petr
1,645件の閲覧回数
PetrS
BR, Petr
