PIM System Safety concept based on MPC5775E
carlos_paternai
Can you please share access or the instructions on how to access the MPC5775E based PIM System safety concept material?
We are engaging in a project where we need to complete the safety activities and work products for a HVTI based on the reference design. Understanding what is available from NXP in terms of safety activities and work products will help us to complete the gap analysis and plan the correponding activities.
From slides from NXP we have found that this should be available:
Also, we would appreciate if you can release the MPC5775E Safety Runtime Framework for Power Inverter Module (Evaluation License)  package with us for its evaluation.
carlos_paternai_1-1759474973176.pngMPC5775B-E  #High Voltag Traction Inverter System safety concept
davidtosenovjan
I have been informed we are not promoting more this solution (PIM2).
Would you possible to move to PIM3 based on S32K39 which is more suitable for new application?
Here you find some information:
https://www.nxp.com/design/design-center/development-boards-and-designs/EV-INVERTERGEN3?tid=vanEV-IN...
carlos_paternai
Thanks, but the fact is that the solution is already in place. what we need is to access to the PIM system safety concept to apply ISO 26262 to existing solution from the customer. Also we need well as the MPC5775E safety framework (evaluation license). Thanks!
davidtosenovjan
You could use :https://www.nxp.com/webapp/Download?colCode=AN14552
Even this is Gen 3 , PIM3 FSC TSC and the System Fault tree analysis are not linked to dedicated HW  and can be used even with the previous generation of MCU.
